Stubborn Lawn Issue
/ Stubborn Lawn Issue #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a lawn issue. I treat for grubs, but I am not sure if this is grub damage.
Any opinions?
I live in NJ
/ Stubborn Lawn Issue #3
Maybe your dog decided to pee there.
/ Stubborn Lawn Issue #4
Does the grass in those brown areas feel loose and lift up? Have you taken a shovel and carefully peeled back the sod and looked for grubs?
/ Stubborn Lawn Issue #5
A few things I’ve found make a difference with stubborn spots:
  • Soil test first – sometimes it’s not a weed or pest issue but pH or nutrient imbalance.
  • Check drainage – areas that stay too wet or too dry can cause grass to thin out no matter what you plant.
  • Overseed with the right grass type – match seed to your region and sun/shade conditions.
  • Address underlying pests or fungus – grubs, chinch bugs, or fungal infections can keep reappearing unless treated directly.
If you can share whether it’s patchy growth, weed takeover, or discolored grass, it’ll be easier to pinpoint the fix. Sometimes it’s a combination of soil health + timing your overseeding and feeding right
Excellent comments guys. Not a dog, looks like Kentucky blue grass that just turned brown.
I will look online how to see if it is fungus, and check for grubs.
/ Stubborn Lawn Issue #7
Tough to tell from the pics, but to me, it looks like those dead spots are in low areas. If so, I concur with the fungus diagnosis.
One way to tell if it's grubs, is to pour a 5 gal bucket of water in one square foot and see if any come to the top of the soil. Or, take a shovel and dig down 4-6" to see if you have any in the same basic area. If you do have grubs, it's either time for another grub treatment, or change the chemical you're using. The best thing I've found is bifenthrin as the active ingredient. Haven't had grubs in over 10 years since I've been using it. Also good to prevent ants, army worms, and bunch of others.
/ Stubborn Lawn Issue #8
Grub damage normally appears is large patches, usually circular, like this:
One give-away is that you can often grab a tuft of grass in the damaged area, and lift it almost like a carpet, as the roots have been eaten away.
It's tough to say if that's what is happening in your photos, but we are only two or three weeks out from the ideal over-seeding window, and you can adjust your grub control application timing next year to try to knock the little bastards down. Usually, you want to aim for mid-June, just a week or two before you typically see the Japanese beetles.
Most of the better grub control products are strong enough that a twice-per year application will put you at or over the legal yearly dosage per acre. So, it's important to get the timing of the one application you're putting down right, as they only have a narrow window of vulnerability to these products.
/ Stubborn Lawn Issue #9
Years ago I applied a product called Milky Spore bacterial powder, after several years I have no grub damage. It takes several years to spread throughout the lawn, and I only applied it on my small maintained backyard. I believe it is very specific to Japanese Beetles and maybe June Bugs.
/ Stubborn Lawn Issue #10
Like RjCorazza, I applied milky spore, see attached pics, to lawn and my japanese beetle population and resulting rose and turf damage went to zero after about two years. Takes some time for spore to spread itself through the ground and kill off the grubs. The spores stay active in the ground for many years and continuously repopulate themselves as new grubs find there way onto my property. The neighbors continually treat with insecticides but don't get the kind of control I do with no more effort than original treatment. My lawn consists of mix of tall fescue, perennial rye grass, and kentucky blue to prevent mono culture and associated issues.
ps. Looks like your grass is mix ( pic ... 352 ) is mix of fescue and kentucky blue
/ Stubborn Lawn Issue #12
Calling @Complete Turf Care . It’d be interesting to get a pro’s take on this.
Sorry, but he is in New Jersey which means he has cool season grass.
I'm just not familiar with cool season grasses to give any advice.
I would suggest he contact his local county agent for help.
thanks guys!
dug up and found no grubs.
But I see the possibility of fungus. I keep the sprinklers on overnight, so that was my first change, I get though all the comments, and get through all those ideas!
/ Stubborn Lawn Issue #14
If you fertilize heavily, then yes, sprinklers overnight will often bring mold. Best to run them early morning, so the lawn has a chance to dry out within a few hours.
Most molds and fungi can be treated, but turf fungicides can be crazy expensive!
/ Stubborn Lawn Issue #15
I should have added one thing: You'll see a lot of advice to break up your yearly nutrient (fertilizer) requirements into at least 5 applications, usuallly 3 in spring and 2 in fall, and to avoid fertilizer application in the hottest part of the summer. I always suspected this was for this very reason, to avoid promoting mold or fungus that thrives on the fertilizer in hot weather, but I suspect @Complete Turf Care knows more about this than me.
Of course, things we can't do to our cool season turf grasses up here, they do every day in the south. Their grasses behave totally different than ours, and probably have different susceptibilities to stuff like this.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
32ft Flatbed Equipment Trailer (A64556)
32ft Flatbed...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
2014 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2014 JOHN DEERE...
