X534 rear wheel hub failure
/ X534 rear wheel hub failure #1
BravoXray
Elite Member
Nothern Indiana
Kubota BX2230, John Deere 430 Diesel
Last week, my cousin called me about his JD mower having a loose right rear wheel. I went over and looked at it, and it looked like the bearing had failed. He brought it over to my shop, and on closer inspection, the hub was loose in the wheel bearing. I'd never seen a all wheel steering mower up close, let alone worked on one, and it looked very similar to a 4WD pickup front axle setup. Because the hub was so loose in the bearing when the weight was off the wheel, the pivot bolts would slide out of the pivot bearings, but wouldn't quite come clear off. The snap sing on the end of the stub axle had one ear broken off, and after struggling with it for a while, I finally fired up the torch and cut it in half. The hub should have just slid off the axle, but required putting a puller on it to force the axle out of the hub. Once that was off, the knuckle and the stub axle and u-joint assembly came off. The pivot pins/bolts are threaded into the upper ear on the transmission end, and on the lower ear on the knuckle. They have a 1 1/8" head, and when I tried removing the one on the axle housing with a long 1/2" breaker bar, and it wouldn't move. Put my big Milwaukee 1/2" impact on it, and it never budged after s couple of minutes of hammering on it. I heated the area with the torch nearly red hot, and it still wouldn't loosen it. So, I pulled out my old Snap-On AT750 3/4" air impact and applied it. It came loose in about 100 milliseconds. Put the knuckle in the vise and hit it with the impact, and that one came right out too.
Got everything cleaned up, and it appears the hub loosened up in the bearing and wore until it got loose enough for it to be noticed. The bearing had worn the hub mating surface barrel shaped, as you can see in the last picture, and actually shrunk the inboard area so the stub axle spline was tight, requiring the puller to push it out. Pulled the snap ring holding the hub bearing in, and pressed it out. The bearing is tight, though noisy and dry, so we are going to replace it, the two pivot bearings, the washer and snap ring.
He should have the parts on Wednesday, looks like ~$400 for all of them. The hub alone was ~$250. JD sure is proud of their parts, like everyone else, I guess.
Should go back together pretty easily and get him back to mowing again soon.
/ X534 rear wheel hub failure #2
Good going. Wish you good luck with this project.
Talked to my cousin today, he has all the parts except the hub, which is on backorder. In other words, they have no idea when or if they will get it. So, I found a couple on Ebay, and he is buying one of those. Should have it by Monday.
/ X534 rear wheel hub failure #4
Nice thread with pictures....keep us updated.
/ X534 rear wheel hub failure #5
I hope it works out well.
All wheel steering - smart idea but...
/ X534 rear wheel hub failure #6
Bravo,
Deere had some problems with older 316, 317, 318 era tractors where wheel weights were added and tractor was used in area with lots of directional changes. There was just enough play in the splines to allow the hub to slowly fret or wear away the splines till tractor stopped moving. Not sure how the X5** series compare in design to those older units.
/ X534 rear wheel hub failure #7
I was tentative about the extra working parts of the first AWS JD 425 I bought in 1998. Held up well for many years while mowing my 6 - 8 acres of lawn, most of it tree-filled and banks and slopes.
Added two JD 455's (one AWS the other conventional front wheel steer). Zero problems with any of them and have over 1000 hours on all of them. Not at all what I expected of the AWS, but the convenience of the AWS kept me locked in on the AWS. Much better traction on side hills, much easier to back up a trailer or wagon behind them, and tighter turns are features that I miss with the conventional 455.
/ X534 rear wheel hub failure #9
Bravo,
Very interesting.
I bought 2 x 50 lb wheel weights for my "new to me" 1987 JD430, but have been reluctant to install them due to way better traction than what I had been expecting!
Just wondering if there has been any reports of similar issues in 430 ?
/ X534 rear wheel hub failure #10
Very interesting.
Not that I recall but memory isn’t what it used to be either.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
KBH Tender (A61307)
KBH Tender (A61307)
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
429970 (A61165)
429970 (A61165)
