/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,851
I just retired my fuel filter. It was the original one.
Thought 20 years was long enough. 😛
How many hours, or gallons did it last?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,852
I saved the piece, but it's not high on my priority list ... Watering again today is!
Filled up in the dark, then started watering ...
Sun was just peaking up when I was over half done with the first of three loads.
We got .65" of rain back on 7/17, nothing since, and it's been HOT out ... Heat index was 107° when I parked Little Baby Fergie in the barn and went inside for a cold shower, the 80° 49% humidity house felt real nice, of course the three cats were inside!
Someday all your work will pay off.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,853
Only 450 hours.
If fairness, I have a diesel pump, that runs the fuel through a big canister filter, making the fuel filter on the tractor purely decorative.
My tractor is pretty much retired, and living the life. The oil engine oil doesn't even get dark anymore. It's changed every two years, with only about 10 hours on it.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,854
I have posted this in the Iseki forum: a lot of thick, black, sooty smoke: injector?
I have 2022 Massey Ferguson GC 1723EB tractor (TLB). It just turned 500 hours recently and it has an Iseki E3112-XB03 engine. I has always had a little bit of black smoke at startup and under heavy load, but it has now started to really pour it out, again, especially under heavy load. It has become a bit harder to start, and smokes then, and it also smoke a bunch when the engine is throttled down from 2500 to 1500 rpm (under no load). It does not seem to have lost a great deal of power, nor does it seem to be guzzling fuel I replaced the fuel filter (it was clean) and the air filter (pretty clean too), gave it the Seafoam treatment: filled the fuel filter bowl with Seafoam (of course, it doesn't hold much) and put the rest in the fuel tank; all of these had no effect. I got fresh fuel from another station, filled the fuel filter with Seafoam again, and put an entire 5.25-ounce bottle of Lucas upper cylinder cleaner with injector cleaners in. Still no change, so I am guessing that I need to clean the injectors.
Is that something I can do myself or do I need to take it to the dealer? Or can any service station do this?
Any tips on removing them? Do I need new gaskets?
TIA, Dick
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,855
I'm not home now, so don't have my service manual handy ... My "guess" would be that they have copper crush washers ... While new ones are "the right way" ... I'm sure many injectors have been put right back in after cleaning ...
Have you tried any of the "mechanic in a can"? That's for diesel ... I'm thinking the seafoam is more gas oriented, but not sure ... I've run Hotshots Hot Shot's Secret Diesel Extreme | Diesel Extreme Fuel Additive twice now ... I see now they also have Diesel Injector Flush | Hot Shot's Secret but have never used it ...
I normally run either there "everyday" or there "winter defense" depending on season, plus a half dose of LX4 Lubricity Extreme: Ultra-Low Sulfur Diesel Additive without getting into politics, the ULSD fuel is hard on pumps and injectors, plus a boost in the cetane also helps it run clean.
Curious if you did the valve check/adjust during the 500 hour service?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,856
Good point(s). I did not adjust the valves (yet).
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,857
Neither did I, just curious ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,858
TIA, Dick
I even thought of the possibility that a "mouse made a house" in the air filter or the inlet & outlet for it so I pulled off the housing and the hoses and cleaned everything. I even soaked the original air filter in soapy water overnight. Looking down into the intake manifold, I saw a bit of soot/carbon and it was a tad wet.
I did pull the injectors and soaked them in gasoline as recommended in the service manual (yes, it says to then soak them in Diesel before re-installing). #2 was black but the cleanest of the batch. #1 had more carbon build-up. #3 had a lot more carbon buildup and was wet. Although I did clean all three of them (I did not disassemble them), I replaced #3 with a new injector, and I used new copper washers on all three.
Good news: I started her up with no air filter and got her outside (cough, cough), but she cleared up very quickly. I then re-installed the original, but now washed, air filter and again she's relatively good. At some point I will re-install the original #3 injector (now soaking in brake cleaner) to see if it was really bad or if all she needed was a little TLC (tender loving care).
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,859
I will say that these little Iseki engines do start hard ... Especially when below freezing ... Even in the summer, mine cranks a bit and then starts with a puff of black smoke on start up after hitting the glow plugs, but that's the only time it smokes ... My Kubota I don't think even gets a full revolution and it's running!
Sounds like poor quality fuel ... I'd try some of that "Everyday" I linked above ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,860
I have not had that experience with mine. It starts right up, with no smoke, even with temperatures in the single digits.
Sorry, typo on the first post of this.
Adams 16T Tender Body (A56436)
Adams 16T Tender...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
1991 Eager Beaver 24ft. T/A Dovetail Equipment Trailer (A56858)
1991 Eager Beaver...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
Riser/Reducer for Water Lines (A57454)
Riser/Reducer for...
Magnetek RDS 500 Diesel Generator (A55272)
Magnetek RDS 500...
