Building a backhoe bucket
/ Building a backhoe bucket #1
Spitzair
Member
Brackendale, BC
Caterpillar, Adams, Hein Werner, Hitachi, Bobcat
So I needed a bucket for my Bobcat 909 backhoe attachment that I just rebuilt. It didn’t come with one and the only one I could find for sale is so far away that shipping would be the same price as the bucket… so I built my own out of some material I had sitting around… I copied the dimensions from my dad’s 303 cat bucket which has almost identical measurements on the bucket linkage. I used a piece of plywood to mock it up…. The cutting edge is some 3/4” hardox I had left over from another project, the sides are 3/8 as is the bottom skin, then the ears are 1/2 and some schedule 120 2” pipe made the perfect pin bosses. Almost looks like a real bucket! Anyway, thought I’d share, it works really good…
/ Building a backhoe bucket #2
Beautiful work. Congratulations.
You've clearly got too much time on your hands - uh, I assume that is you in the photo.
And I particularly enjoyed the picture of the plywood mock up. What's next?
/ Building a backhoe bucket #3
put a couple holes in the middle of the bucket so water can drain out ,
weld a chain hook on the bucket beats the teeth if you ever need a chain
/ Building a backhoe bucket #4
Nice work.
Those are 2 features that you rarely get in a new $1200 bucket. I have done two homemade buckets myself, and they were very rewarding.
I have always wondered how effective the skidsteer-mounted excavators are. Is yours the kind that is operated from the SS seat?
Thanks guys. No, that’s not me in the pictures, that’s my son/top helper…
I do have a chain hook welded to the back of the bucket, already came in handy a few times.
This one you operate from a seat on the attachment itself, I still have to mount it, right now I just have the mounting plate on there, not the most comfy thing to sit on… sure has great visibility. Haven’t used it much yet but from what I have done with it so far it has great power and breakout force, can’t wait to use it more! I think I’ll build a ripper tooth for it next…
/ Building a backhoe bucket #6
I look forward to seeing the ripper tooth project. I could definitely use one of those myself.
Doug
/ Building a backhoe bucket #7
Call me jealous! Nice job!
All I'd get if I tried to weld two pieces together, would be a yard-fire lol
Haha, my yard didn’t burn but I did catch myself on fire while building this bucket.
I brought the back sheet to the local machine shop and they curved it on their brake for me, I don’t have a good way of bending it here at my little shop…
/ Building a backhoe bucket #10
Did you use 1/4" or thicker plate?
On my first bucket, I used 1/4" x 13" plate, and bent it around side plates I had cut out. I used an O/A torch to heat it where I wanted it to bend, while pulling on it with a cable-jack come-along. I bent a bit, welded the sides, bent some more, then repeated the process.
On the 2nd one that I recently did for my mini-X, I opted for thinner steel, so the bending was easier (no heat). Then I added welded-on wear plates.
No special tools.
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
2010 GMC W5500 HD 16FT Box Truck (A61573)
2010 GMC W5500 HD...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2005 Peterbilt 357 Tri-Axle Dump Truck (A61573)
2005 Peterbilt 357...
