Weed wacker - extending string life
/ Weed wacker - extending string life #41
Just don't mix them up, I imagine Cat5 is as bad for mowing as trimmer line is for signal propagation.
Very true but I trimmed around a 12ac pond, 50 RVs & their sites and assorted tent sites for almost 20 years. Add trimming around the the 4 other ponds, creek and other steep areas and we used go through one of those spools in less than 2 years. No I'm doing as little trimming as possible, to point of ripping out flower beds so I don't have to.. 🤣
/ Weed wacker - extending string life #42
Supposedly, soaking/ storing trimmer line in water reduces line breaking. I personally don't see how that's possible and I don't do it.
Check the trimmer head eyelets for irregularities, or try a different brand and/or diameter of string.
trimmer line is nylon and when hydrated it makes it stronger as nylon over time gets brittle so soaking it in water hydratesit and makes it stronger so it won't break so easily and it lasts longer
/ Weed wacker - extending string life #43
Hah, you just made me think that my bulk trimmer line storage location atop the wall header and jammed between the rafters just under a hot metal roof might not be the best location. :D I have a fully air-conditioned shop, but that space isn't unlimited, and outdoor tools and supplies usually stay out in the un-insulated shed.
I learned long ago items kept inside my service van often succumbed to heat… like paint can lids opening, rubber gaskets and my mounted Honda Generator…
The gas powered tools kept in the walk to daylight basement seem to keep best… it’s dry and cool with very little temp swing…
The metal garden shed is the worst except for picks and shovels…
/ Weed wacker - extending string life #44
Have 628 ft of privacy fence at my house in TN along with assorted buildings. 41 acre farm in KY. Most of my trimming at house is with Glyphosate and at farm. No way would I attempt trimming with just a string trimmer and brush blade. Maybe 15 minutes /wk. with string trimmer at house and a couple times a year at farm with brush cutter.
/ Weed wacker - extending string life #45
When I am trimming around trees, shrubs and walk ways, I use the Echo 0.95 Black Diamond line. It cuts well and isn't too noisy. When I have lots of rocks/rock walls to trim around, I use the Oregon Magnum Gatorline as it has an inner core of Kevlar, or something like that. It stands up to the abuse better, but it doesn't cut as well as the Echo and is noisier.
/ Weed wacker - extending string life #46
The Black Diamond line is not as loud as other lines I have used.
I can’t say it’s the best ever but it’s my current favorite.
My brother uses the cam lock on the farm and I asked him why… simple answer is some of the guys can’t reload a bump head… he had a guy hired to trim for the day and all started fine…
My brother left to do another chore and when he came back the guy was fussing around a good 45 minutes not able to load line.
With the cam lock no instruction or tutorials needed…
/ Weed wacker - extending string life #47
Some of the worst lines I’ve used would weld themselves together when cutting nonstop.
It’s always been round line that gets hot enough to fuse together.
Only hit a ground nest once… got many stings from kamikaze wasps that time…
/ Weed wacker - extending string life #48
I wish I could find my trimmer line. I put it some place where it wouldn't get lost. :rolleyes: I'm sure it's not lost. I just can't find it. 😀
Unless it was a lifetime supply just buy another, As soon as you can't return the new one the misplaced one will turn up.
/ Weed wacker - extending string life #49
I have a Stihl weed wacker that I like but seem to break a spool worth of string every couple weeks.
What am I doing wrong? What’s the proper way to use it? Thanks.
IME, the biggest variable in breaking the line is the patience of the operator. The END of the string is what does the cutting. If you take your time, the end will gradually wear down, and then you can pull out some more.
If you put the head right up against what it is supposed to cut, it is more apt to break off. It is especially important to leave space between the head and any uncuttable object.
Your problem may be different, but this is what I've seen.
/ Weed wacker - extending string life #50
I don't understand why everyone has a problem with the line not lasting. More than 15 years ago, I bought a spool of fishing line in a suitable size. I'm using it more often lately and still get at least a year out of rewinding new line on the spool. Did I luck out on some fancy material or am I doing something right, but not aware of it?
/ Weed wacker - extending string life #51
Or you only have 10’ of working area.
/ Weed wacker - extending string life #52
I just bought a 700’ spool of Black Diamond tonight…
I guess AI saw my post and sent advertisements for same?
/ Weed wacker - extending string life #53
I have seen many suggestions to soak the line in water.
Is there any other fluid that might work better than water, or is there an additive that might make the water work better?
/ Weed wacker - extending string life #54
The 3 rotating Stihl knives cut like butter but snap if contact made with old fence wire or rock…
I agree! I have one of those and stopped using it because the blades were not lasting as long as I wanted them to. I still have the head and one day I want to cut the blades out on my cnc machine.
/ Weed wacker - extending string life #55
If you have metal eyelets on your head, check them to make sure that they aren't scored. When mine get that way they cause the string to heat up and break. I simply rotate the metal eyelets a little so the string does ride on the scored area.
/ Weed wacker - extending string life #56
Soak it in water for a day or 2 before installing it. It gets dry and brittle. Stihl recommends that you soak it to revitalize it.
/ Weed wacker - extending string life #57
Jack Daniel’s? It won’t help the trimmer line anymore than water but your likely to do a shot and get less upset.
/ Weed wacker - extending string life #58
We use a lot of string each summer. What makes them break off, or last a long time is kind of a mystery. We have cut all day, 8 or more hours utilizing the same three stings. Then the next time out you loose them in 1/2 an hour. Seems like the dryness of the grass n tree shoots or species you're cutting is the difference. We always carry extra 155 strings along so it's not a big deal, either way. Of course if you have fencing to work around, it goes fast.
/ Weed wacker - extending string life #59
next time your string breaks, take a look at the wound spool: you'll see the break occurs when one line is crossed over another, melted & broke. i'll wager 90% of what members are complaining about here is due not to line failure, but improperly wound trimmer line. do not cross one line over the other. simple fix
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
