SSQA Snow/dirt plow blades
   / SSQA Snow/dirt plow blades #21
Made my own using an ancient PU truck plow. Yes I have the JD QA plates, but the skid steer plates are cheap, then just add some pins. I don't even use the 3rd function anymore. I borrow the curl circuit one a specific angle is planted. I had to get used to the length out front.
Since then, I've gone to using a 60" broom for snow on my lawnmower (JD-1435) 90402086.jpgIMG_20221111_095321_01.jpg20231231_171927.jpg
   / SSQA Snow/dirt plow blades #22
I have used both style mounts and I really prefer a direct mount on the tractor instead of a loader mount. As another responder said the long set up on a loader tends to push the tractor around.
I bought a used 9' blade in good condition for around $400.00 and made my own mount. I use the loader valve to control the lift and power angle.
   / SSQA Snow/dirt plow blades #23
Get a V-plow with a trip for snow.
   / SSQA Snow/dirt plow blades #24
I've used SSQA FEL mounted plows on all 7 of my Kubota tractors plowing my 1.25 mile sloped private road. I'm currently using an 8' Land Pride plow on my MX5800 and L6060. I've had great results using chains on the front tires only. My BIL uses the same plow on his M59 and it works just as well.
Yes, the plow sticks out in front and can cause deflection issues, but I find they are easily overcome by lifting the blade slightly. this adds weight to the front tires and gains traction. I particularly like that you can pile snow to heights of 10' or more if necessary.
I plowed with a pickup for years but find using a FEL plow is much faster, more maneuverable, and more convenient. It also puts the work on a machine designed for the purpose rather than beating the heck out of an expensive pickup.
   / SSQA Snow/dirt plow blades #25
TTWT sure likes the direct attach plow VS the FEL attached plow.
   / SSQA Snow/dirt plow blades #26
Google "Minnesota Implement," go to their site, and then "snow removal" Snow Removal to see light weight, standard duty, heavy duty, and super duty cross draw snowplows. Scroll down for videos.
I have a standard duty 7' cross draw plow for my Kubota L45. Yaw (rotation about the vertical axis) or Power angle is provided by the front remotes; pitch (rotation about the transverse axis) is provided by the loader control of bucket; and roll (rotation about the longitudinal axis) or "tilt?" by intentional slop in the design (see video). I have no mechanical complaint about the attachment and will recommend Minnesota Implement. My son has a surfeit of unconsolidated 3/8" crushed stone on his driveway. Despite fabricating 11 x 15" skids to try and float the plow, both the plow and the skids bulldozed those stone chips leaving a pile of chips and two ruts in what remained.
   / SSQA Snow/dirt plow blades #27
Google "Minnesota Implement," go to their site, and then "snow removal" Snow Removalto see light weight, standard duty, heavy duty, and super duty cross draw snowplows. Scroll down for videos.
YES! ^^^ He has many good ideas in his plows and he would surly be one place to look into!
   / SSQA Snow/dirt plow blades #28
He says in the video the plow mount blade is too heavy when plowing in the float position.
Anybody that has tried to use a loader mounted snow plow with the loader in float position for more than 2 minutes pushing any amount of snow knows it doesn't work.
Take the loader out of float and raise some pressure off the front blade and the problem goes away.
Simple.
   / SSQA Snow/dirt plow blades #29
Simple.
What if your driveway isn't flat? Even being out of float it doesn't change the fact that the geometry doesn't work with a FEL as the force pushes up at an angle to the FEL pivots. That will always want to raise the front wheels off the ground. A direct mount plow on a tractor or truck pushes STRAIGHT back to the frame, not up to a point 5 feet off the ground.
   / SSQA Snow/dirt plow blades #30
I've been plowing with a FEL mounted snow plow for decades.
It never try's to raise the front wheels off the ground !! ( If you have the loader in float it will, I never use float it doesn't work, been there/tried that )
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
1987 International 1954 Elliott ECE 3-65H Boom Lift Truck (A56858)
1987 International...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1998 MACK RD688S 80 BBL BOBTAIL VACCUM. (A58214)
1998 MACK RD688S...
