Good morning!!!!
   / Good morning!!!! #209,701
Low this morning 58.6 high in 70s delightful to say the least. Did not sleep well what’s new. Wngsprd your son was not to far away.
No nurse help today so it’s just me.
Sorry about your friend Drew
Prayers for all our Countey
   / Good morning!!!! #209,705
Good morning, low 57 and going up to 81°F. Wind W m6 mph. Smoke. When the powers that be forecast smoke you know it is going to be a grey day.
Was going to clean up the mower and change blades today. I may do that anyway. Nothing else planned.
Have a safe day all
   / Good morning!!!! #209,706
50F sunny day low 80's for high.
Plans for today...finish wheel barrowing rest of the wood in basement,cut 3 low hanging limds,check game cams rest of the day numb it.
Enjoy you day all.
   / Good morning!!!! #209,707
Good Morning from Central Texas.
Close to 71 with almost the same dew point. Headed to upper 90's again. Unclear what if anything I can force myself to work on outdoors today except water some of the garden pots. Just too miserable weather.:)
Reading thru some of the "Northerners" posts, I am envious of the 70's or 80's high temps. But, it is August in Texas and we have about 2 more months of scalding heat only interrupted if a system comes in off the gulf.
Hope all enjoy the day !
   / Good morning!!!! #209,708
good morning, 58 going to 80 another great day
Worked on cleaning up the welding table top from rust and residuals using rotating drum tool and 8 inch angle grinder with sanding disks but still not happy with it. Need to look into more aggressive sanding disks
Plan to do some string trimmer work today
   / Good morning!!!! #209,709
I used a belt sander with 80 grit belts when I repurposed a piece of used 3/4” plate into my welding table. It worked pretty well.
   / Good morning!!!! #209,710
Thank you, forgot about the belt sander. Will check into what grit sanding belts I have on hand and try it out
The welding table is very sturdy but the top is not thick enough to use the insert welding clamps. A 3/4 inch top on top of the existing top would be much better if I could find it
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
489 (A52708)
489 (A52708)
JOHN DEERE LOADER BRACKETS FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE LOADER...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
Kubota R5205 (A57148)
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
