Florescent Lighting Bans?
/ Florescent Lighting Bans? #41
I did have two LED outdoor fixtures that went bad after a year at one of my employer's buildings. I opened one up and found it stuffed full of packing paper, so it overheated and cooked. The other was stuffed with bird nest and got cooked as well.
Some of the apartments went to LED fixtures and now when it does not work it’s on the property owner…
/ Florescent Lighting Bans? #43
I replaced the T8 eight foot fluorescents in my shop and garage in Aug of 2021 with LEDs nor using ballasts. Eight foot fluorescent tube were hard to find and replacement ballast were non existent. Thus far, they are still functioning well and are super bright (really nice for the shop).
I have also replaced all the smaller fluorescents tubes in the house except the two footers underneath the kitchen cabinets. They are original to the house (built in 1886). They are not used very much but still are still functioning.
Options are good… mandates not so good.
I wish California didn’t feel it has to always be the early adopter test case for nation and world.
I remember when fluorescents were mandated… now it’s the mercury causing issues but we recycle all our fluorescent bulbs… nothing ever to the landfill.
It’s against the law to dispose of fluorescents in landfill trash so how is this a problem in 2025?
Picture of the LED tube supply chain requires for the entire 80,000 employee enterprise… I am but a dot on the location map.
My 1995 T8 ballasts are Instant Start but not all Instant Start Ballast are the same
Just checked and the current price is up 30% from last month…
Rated Life50,000 hr
Rough ServiceNo
Shatter-ResistantNo
StandardscULus Classified; DLC
Start TypeInstant
UL 1993 Environmental RatingDamp Location
UL TypeType A
Voltage120 to 277V AC
Wattage14 W
UNSPSC39112102
Country of OriginChina (subject to change)
Product Description
LED UL Type A linear lamps are plug-and-play to install into an existing fluorescent light fixture and operate from its ballast, so there's no need to rewire, add drivers, or modify electrical components. They allow a simple transition when upgrading from fluorescent lamps to more energy efficient, longer lasting LEDs. For proper operation, installers must verify that these light bulbs are compatible with fixture ballasts
/ Florescent Lighting Bans? #47
I can understand the frustration of having this change forced upon you, but IME the LEDs are superior to the fluorescents in all respects. They use less electricity, they are more reliable, they provide better lighting, and they eliminate the need to maintain ballasts.
I haven't tried the LEDs that allow you to keep the ballasts in place, but that seems to defeat the purpose. The ballast makes the fixture less efficient, and it adds another point of failure.
There is the one-time investment in some labor to remove and bypass the ballast and buy the LED tubes. From that point forward, it's all positive IME.
/ Florescent Lighting Bans? #48
Of course you're correct. But outlawing the sale of only new fluorescent fixtures, rather than the bulbs, would be a much less disruptive means of eventually achieving the same result, without forcing immediate costs onto every property owner.
If the sale of new fixtures were banned, the demand for bulbs would diminish over time, to where finally the bulb pricing increases to the point where the last few stragglers convert. But in the majority of cases, the aging-out of old fixtures and ballasts would have most already converted, long before the bulbs ultimately went NLA.
/ Florescent Lighting Bans? #49
I have a 4 bulb fixture in our house. Only two of the bulbs have burned out in 30 years. They are 130V bulbs and very heavy glass. I'll be sad when the last one goes. (or maybe dead 🙃 )
Those 130v bulbs were usually sourced from Canada. My local supply house used to sell them. I have incandescent 60,75 and 100s that have been burning for many, many years. Heck, my R30 can lights were installed over 15 years ago in basement and i can only remember replacing 1 lamp. There are 20 can lights down there.
/ Florescent Lighting Bans? #50
These rarely-achieved lifetime estimates are usually based on the LED itself, which will legitimately last damn near forever. The trouble is that any electrolytic or tantalum capacitors used in the driver circuit may have lifespans of just 10,000 - 20,000 hours. So what you end up with is a good LED array in a bad bulb assembly, which is just as useless as a dead LED array.
But the LEDs themselves seem to fail too, as I mentioned upthread with the "Christmas light" strings I have in my living room. All they are is a bunch of LEDs in series with a load resistor, but I get a couple years out of a string before I start losing bulbs. Took one partially bad string and pulled all the good lamps for spares. I seem to see a lot of LED arrays in other products where there are a lot of bad lamps.
Not sure how the COB lights work.
/ Florescent Lighting Bans? #51
Do they make 8' LED replacement tubes? A neighbor had a bunch in his garage and wasn't able to find any, but this was a few years ago.
/ Florescent Lighting Bans? #52
You sure you meant to quote me there, Oak?
/ Florescent Lighting Bans? #53
Yes. Satco makes 8 foot led with several kinds of tumbstone mounting ends. I replaced my old HO lamps with the 8foot tubes in the horse barn last year. On mine i used direct wire lamps and cut out the ballast. Way brighter than my old HO lamps, and arnt affected my moisture when snow melts like the old lamps were.
/ Florescent Lighting Bans? #54
I agree, but that wouldn't be the California way. ;)
This is the land that pays people to inspect your garbage, and they will fine you for throwing away recyclable materials.
If someone breaks into your car, don't bother calling the police. They won't respond to that sort of thing. 🤪
/ Florescent Lighting Bans? #55
I have been avoiding reading the news for quite a while now, but back when I was still reading it, my best friend and I used to call each other with California and Northeastern horror woke stories. We always say the same thing: "I think it's great."
I remember reading a California story about giving people incredible sums as reparations, and all I could think was, "Do it do it do it do it." People who hide from the truth need to hit rock bottom before they will do anything to change course.
I throw used oil filters in the trash. Come arrest me.
/ Florescent Lighting Bans? #57
Theres no law against that, just make sure there empty of oil.
/ Florescent Lighting Bans? #58
You don't really want to hear about a local law no one actually obeys.
It can be really difficult disposing of oily trash properly. You really have to work to keep oil and fuel from slopping out and landing on things like weeds and fresh stumps.
What about tossing hearing aid or flashlight batteries?
Big trouble if recycling ordinance isn’t obeyed…
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
1999 John Deere 544H Articulated Wheel Loader (A61567)
1999 John Deere...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
2016 Big Tex 50LA Double Axle Utility Trailer (A61165)
2016 Big Tex 50LA...
2006 Peterbilt 387 Semi (A64047)
2006 Peterbilt 387...
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
