HamishMacCheap
- Joined
- Oct 26, 2024
- Messages
- 96
- Location
- South Carolina
- Tractor
- John Deere 3043, Kubota LX2610SU, Kubota L3302
I think Kubota recommends the FEL on my LX2610 be greased every 10 hours. I follow their recommendations.
How do you like that machine?I think Kubota recommends the FEL on my LX2610 be greased every 10 hours. I follow their recommendations.
Different equipment different needs. A one off nobody can plan for. If I was in construction it would be a different story.That's all well and good until you rent a skid steer and the track pops off. Try refilling the grease on that with a manual grease gun. Your hands/forearms will hate you.
Lock and lube yellow gun.I used to think about getting new grease in my 5 gallon grease bucket that refilled hand grease guns. Wish I had done it years ago.
Easier and faster than changing a tube of grease. Best used with a grease gun that the rod comes out as the grease gun is filled
Never have an air problem.
Does anybody have a recommendation for a good quality pistol grip grease gun?
Mine are old and failing
I had 4. One for each shed. I'm down to one. And it's leaking past the plunger. I'm wishing I had looked into fixing the others.
The guns I have bought since, suck
A lot of squeezing and not much grease pumping.
Sad to say, my wife had done all of the greasing this year.
How does that equate to hours? My skidsteer I do them every 10 hours. Over kill but if I forget or get busy I'm still good and do them at next 10 hour. Newer tractors are 50 hour fittings, older Tractors are 10 hour. I do them at 25 hour. All are done per hour meter on equipment. Still overkill because obviously there is running but no movement.I like to grease my skid steer and excavator bucket pins every 1/2 tank of fuel and the rest of the pins every tank of fuel. I’m not sure what you’re greasing every 100 hours.
You're right! But at the same time, 24 zerks on a zero turn seems kinda ridiculous. Didn't anyone tell Kubota the rest of the world switched over to sealed bearings for most applications, 40 years ago?
Even the idlers on my 2007 Deere mower deck are all sealed bearings, the only greasible things there are the three main spindles. Everything else that gets greased on that machine is a non-bearing pivot, such as mower deck trailing arms and brake linkage.
Most sealed bearings have a service life that's many times longer than the lifespan of a commercial zero turn mower, so they're an ideal application case.
10 operating would be my assumption. I grease loader as I feel it needs done. Just like all my implements I guesstimate the hours it’s run. If handling round or square bales. Loader gets done every day otherwise whenever I feel it needs itI always wondered if the recommendation is for 10 engine operating hours or 10 hours using the loader.
