Yanmar YM1510D – Front Wheel Assist Not Working
   / Yanmar YM1510D – Front Wheel Assist Not Working #1
YanmarMatt
Yanmar ym1510d
I’m having an issue with the front wheel assist (4WD) on my Yanmar YM1510D and could really use your insights. Here’s the situation:
When I jack up the front of the tractor, I can spin one front wheel by hand and the other turns in the opposite direction, but it seems like it takes a minute to “catch”.
I also occasionally hear a metal-on-metal grinding sound, but it’s not overly loud or constant. Just enough to make me concerned. It doesn’t clunk or pop; more like a soft grinding that comes and goes.
Leaking + Low Fluid
The front axle fluid is definitely low, and I suspect a leaky gasket or seal. I have noticeable oil residue inside both front wheels, so I think fluid is leaking from the hub area or knuckles. I haven’t cracked anything open yet, but I assume this could be contributing to the problem — potentially insufficient lubrication of gears.
When It Started
This issue began while I was hauling and spreading rock, so the front end was under load. That’s when I first noticed the delayed engagement and the occasional noise. Before that, 4WD seemed to operate normal.
Tests So Far
  • With the front lifted, both wheels turn opposite directions — no obvious binding.
  • I haven’t drained the fluid yet to check for shavings or signs of damage.
  • I haven’t opened the front differential or center joint yet either.
Looking for Advice
I’m hoping it’s not a stripped gear or something major. I’d really appreciate advice on:
  • Whether this sounds like normal open diff behavior or a sign of internal wear
  • How critical it is to fix the leak before diagnosing further. Any insight on how to fix the leak as well.
  • What internal parts could cause this delayed front axle engagement
  • Any tips on what to look for if I open up the front axle or center drive shaft
Thanks in advance for any help you can offer. I’ll try to get some photos of the leak area if that helps. Let me know if I should try any specific test or inspection.
— Matt
   / Yanmar YM1510D – Front Wheel Assist Not Working #2
I would think there is a problem. There should be minimal slack when rotating tires. Only caused from minimal gear backlash. My first thought would be differential spider gears but I won't try to speculate on exactly what is causing your excess movement.
   / Yanmar YM1510D – Front Wheel Assist Not Working #3
Leaking + Low Fluid
When It Started
Tests So Far
Looking for Advice
— MattView attachment 3825593
See this thread for helps. (y)
   / Yanmar YM1510D – Front Wheel Assist Not Working #4
The wheels spinning opposite directions when the 4wd input shaft is unable to turn is normal. If the 4wd shaft is allowed to turn then both front wheels can (but still might not) spin the same direction. If by "a minute" you mean less than a revolution then the delay could be caused by a loose or broken U-joint allowing the driveshaft to spin a little bit before stopping. This can cause a grinding metal sound from the bad bearings and can even let the shaft contact the metal shroud causing a metallic sound. If you mean you actually have to spin the wheel multiple revolutions then it sounds like a gear has probably lost some teeth. Just a guess though.
I, personally, would not worry about the leak until I got the main problem diagnosed & fixed.
The driveshaft U-Joint would be my first suspect. If it was an internal gear then I think you would have a different set of symptoms (grinding, binding, popping, slipping). It could also be a bad or broken bearing letting things get a little loose but I think you would have more serious symptoms.
The U-Joint can be seen just by removing the 4wd driveshaft cover. If you have to take apart the differential or knuckles then just look for any metal pieces, or missing teeth on gears, or anything loose that should not be.
Running those axle low on oil (or with bad sounds) is really risky. There are a couple gears in there that are very hard to find and you do not want to damage them.
Hope this helps
Aaron
   / Yanmar YM1510D – Front Wheel Assist Not Working #5
And those U-Joints are near impossible to find. I discovered they were also used for a couple of years on the rear axles of a Honda ATV - and cost less, purchased that way.
I looked up my 2009 notes for the previous YM186D (no loader) that I sold several years ago:
HONDA ATV models:
1985 ODYSSEY (FL350) REAR SHAFT
Part # ATV300 $249
* These may fit other Arctic Cat models.
Or Ebay:
American CV
1985 ODYSSEY (FL350) Rear Axle Shafts Standard U-Joint
Price: $29.95
[in 2009]
   / Yanmar YM1510D – Front Wheel Assist Not Working #6
1510D bearings and seals.
Hope this helps
Aaron
Thanks for the insight. I progressed through your suggestions then found these gears on both left and right with some teeth missing. In a quick search this seems to be one of the hard parts to find, correct? Part #194441‑13950 I believe it is called the front‑final drive bevel gear. I reached out to lens12 as I saw he may have had some machined at one point. Any other ideas how to locate two of these?
   / Yanmar YM1510D – Front Wheel Assist Not Working #8
My guess the YM1500 and the YM1510 uses the same Gears. The 1510 does not show up in my book. So many models listed. Fredricks Importing parts. Try them they may have it.
   / Yanmar YM1510D – Front Wheel Assist Not Working #9
Unfortunately that gear is only used on the YM1510D. I really don't think that one looks like it would cause the problem you described though. If it were me, and I could not find a replacement, I would use it. Just file down the rough/thin edges so they didn't keep chipping off, make sure the mating gear looked OK, and that there were not any metal chunks still in there. There is still a lot of good contact area on each tooth and those gears don't spin very fast.
   / Yanmar YM1510D – Front Wheel Assist Not Working #10
Interesting! The YM2000D and the And the YM2010D use the same Gear, front axel. . SG-1352 YM195-2420 no Ym1500 etc.. Better get a good file!
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
207271 (A52708)
207271 (A52708)
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
