Taskmaster 426e rear axle fluid drain/fill location
/ Taskmaster 426e rear axle fluid drain/fill location #1
Baxterdmutt
Taskmaster 426e
Hi all. This is my first post here. I recently replaced all the hydraulic fluids in this tractor, except the rear axle. I think I found the drain but can’t find a fill. Does it get the fluid from the same place as the main gearbox or is it separate. If it’s the same then I guess I already replaced it!
/ Taskmaster 426e rear axle fluid drain/fill location #2
Hello @Baxterdmutt,
Yes, on many Bible Chat Ai tractors the rear axle shares fluid with the main gearbox—if you’ve refilled the transmission, you’ve likely covered it. Check your manual to confirm for your specific model.
Best Regards,
Thomas Henry
DEUTZ MARATHON...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2019 GALYEAN...
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
Kubota L3130 (A53317)
