Ground hornets! [emoji2962]
/ Ground hornets! #121
Not ground hornets...but boat hornets!
Getting ready for some fall fishing...gingerly uncovered the boat and carefully opened the hatches...
S.U.R.P.R.I.S.E...!!!
(This pic is after the first midnight "Raide". It took two attacks to finally get all the demons exorcized!)
/ Ground hornets! #124
Guess the answer is to go fishing more often so the buggers don't get a chance to move in...
/ Ground hornets! #125
I got stung about six times two weeks ago and I still itch where they got me. My property is on a ridge with trees almost all the way around. I was weed whacking the area around the trees up to where the ground slopes off so that the leaves will blow down over the bank. Having not trimmed since last year, it was pretty overgrown so I never saw it coming.
The wasp spray that I had on hand was about empty but I did manage to kill a few until I bought more spray. Then I went out after dark with a headlamp to light the way. I sprayed a little at the hole then poked it with a stick to open it up and then pretty much emptied the can on it.
Next day, no bees. I walked by there today. The hole was dug open and there were pieces of the nest laying around the opening. No idea what critter had dug the nest out? The hole was huge! I had no idea that the bees could build like that!
/ Ground hornets! #126
At least around here, skunks are the usual destroyer of these ground hornet nests. It's an endearing quality of theirs, that somewhat makes up for their smell.
/ Ground hornets! #127
I love my local black bears because they usually find and dig out the ground hornets/ yellow jackets and feast on the grubs. I just look for smashed down grass and dirt piles when mowing and pay special attention when I see those signs. Occasionally the bears can't dig deep enough and I come back at night with a load of dirt in the hoe bucket and drop and tamp that dirt down hard. Nasty buggers can't dig their way back out if I hadn't already crushed the nest. Fun with backhoe. :)
/ Ground hornets! #128
I discovered a ground nest of bees this weekend located right next to my water spigot that I had the kids turning on/off for me so lucky they did not get stung. Looks like I am gonna pour a little gas in it this evening and cover with a scoop of dirt. Hopefully that resolves the issue...
/ Ground hornets! #129
Seven dust works also but it takes a few days. I've dumped about 1/2 cup right on top of the hole during the day using a long stick (6-8') with yogurt container screwed to it. Dump and walk away. They will crawl trough the dust brining it into the hive and after a few days their are all dead.
Let us know how the gasoline works, it may be much quicker, good luck.
/ Ground hornets! #130
Mix gasoline and diesel 50-50, pour in hole and light it. It will burn slowly due to the diesel and not be explosive.
/ Ground hornets! #131
No need to light, with gasoline. In fact, it probably works better if you don't light it, as it's the heavier-than-air fumes that do the killing... essentially suffocating them.
I guess that lighting it off after they're all dead the next day can be bonus fun, but I'm usually curious to dig it out and see how big it was.
/ Ground hornets! #132
Yeah I won't be lighting anything. My natural gas meter is 6 feet away. 😁
/ Ground hornets! #135
Don’t EVER confuse and call nasty useless yellow jackets.. ā€œbeesā€.
They are NOT bees
/ Ground hornets! #136
But lighting the hole is more fun. I do this also for big ant mounds.
/ Ground hornets! #137
My Dad swore gasoline was the best way to get rid of moles and gophers.
/ Ground hornets! #138
Overnight pretty much. Fumes.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
