I Went To Purchase A New Mini-Excavator And This Happened.....
/ I Went To Purchase A New Mini-Excavator And This Happened..... #151
Why are most of you bashing him for not accepting w/e the dealer decided to send? Wherever that machine came from, the dealership should have been completely embarrassed and apologetic about delivering "new" in any condition other than complete, clean and serviced ready to work.
The owners, sales, service and delivery all skipped the fact this "new" piece of equipment wasn't ready to be delivered.
The OP isn't pissed at the machine, the dealer experience screwed the whole deal.
Because he is complaining about pennies while burning $100 in the process.
loosing 0% and a deal being made to get a machine he wanted while complaining about 7.1 hrs and some dirt. dirt could have been rectified by the good dealer and a honest sit down of where did these 7 hrs come from
/ I Went To Purchase A New Mini-Excavator And This Happened..... #152
I ,ve lost track, where is John at now re a new unit ?
/ I Went To Purchase A New Mini-Excavator And This Happened..... #153
Are you sure that's what it was or did he perhaps feel some deception on the dealers end?
/ I Went To Purchase A New Mini-Excavator And This Happened..... #154
look at the blade in the front... not seeing a single scratch.
Yes, that blade….. Why is that blade assembly absolutely spotless, no dust or dirt, but the main machine is covered in dust, and dirt? 🤔
Is that assembly made with magic anti-dust/dirt paint?
/ I Went To Purchase A New Mini-Excavator And This Happened..... #155
grey doesn't show dust
/ I Went To Purchase A New Mini-Excavator And This Happened..... #156
So your theory is they washed and waxed the blade and only the blade? Or they replaced the entire blade assembly?
/ I Went To Purchase A New Mini-Excavator And This Happened..... #158
It’s not absolutely spotless it’s almost as dirty as the rest of the machine plus it’s up under the machine that would keep it cleaner. Do you have a shred of evidence besides being slightly cleaner that they changed the blade? If the most careful mechanic in the world changed the blade don’t you think they would have hit the whole machine with a power washer when they were done? The next fault in your theory is why would you change a blade to start with? If it was delivered so jacked up that the only solution was swapping it do you really think it took 7 hours to identify? A blade is a pretty simple tool and it if was jacked up you would know right away not 7 hours later.
/ I Went To Purchase A New Mini-Excavator And This Happened..... #159
Either one, by the looks of it.
Which is more likely?
/ I Went To Purchase A New Mini-Excavator And This Happened..... #160
Right….🙄
  • Good Post
Reactions: D&D
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
