John Deere 6400 will not start!
/ John Deere 6400 will not start! #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
Ok had some issues starting and we thought it was battery cables so we took them off cleaned posts and it worked for awhile then had issues again and would wiggle the four small gauge ground wires and it would start. When we had issues it would click click and then try to turn over but was weak. If you keep working the key it would finally just out of no where just fire off. Battery is good even jumped it and didn't make a difference. We followed wires back all the way to the starter and alternator and they are all i place. To the point now even trying multiple times wiggling wires or working the key off and on it won't go.
I am starting to think it might be the starter or solenoid? Do I have to remove the starter to know if the solenoid/starter is still good? Can it be tested on the tractor? TIA
/ John Deere 6400 will not start! #2
I’d start out by load testing the battery. I know jumping it makes you think it’s not the battery and it probably not but everyone should have a load tester. JD’s are known for having batteries that act like you describe or just suddenly die. Depending on what’s wrong with the battery jumping it won’t always work.
There is also a chance something is wrong with all the safety switches plus a starter or a relay.
I put a new battery i had in it and same
/ John Deere 6400 will not start! #5
The way to test the starter in the tractor would be to go straight to the starter with a hot jumper wire to the battery. Don’t ask me how to do this in a safe manner though.
/ John Deere 6400 will not start! #6
Get yourself a “remote starter switch”..
It’s just 2 alligator clips with a push button between..
They can be had at any auto parts store..& the instructions r in the box..
ok got it figured out found the solenoid and did the old screw driver trick started right up. Need a new solenoid.
/ John Deere 6400 will not start! #8
When you state shorted across with a screwdriver which solenoid relay did you short across? Item # 1 or part in shaded outline on starter?
two big studs/wires
/ John Deere 6400 will not start! #10
Hi master raft. If you can get to the starter and such you can. Heck it right where it is. You may need a piece of heavy wire to bypass the solenoid switch with. Keep on and you will finally fix it. I don’t understand why the starter turned slowly
/ John Deere 6400 will not start! #11
The relay in your photo needs to have a ""good ground connection to frame to operate correctly on one small terminal"" & 12 volts from ign switch on other small terminal when ign switch is moved to start position. The larger posts on that relay provide 12 volts to "S terminal on starter solenoid" when ign switch is in start position..
ROAD GEAR ALUMINUM HEADACHE RACK W/CHAIN RACKS (A64277)
ROAD GEAR ALUMINUM...
Bucket (A64194)
Bucket (A64194)
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
