Bush hog Q
/ Bush hog Q #1
repete
SW Washington
L2550DT IH584-4WD
I have an old 5' brush hog I use for mowing rough stuff. I do not know the maker.
My question is are the blades and bolts generic for these machines. My blades measure 24"
/ Bush hog Q #2
The blades are pretty interchangeable between cutters in lots of cases.
I would take the old blades off, and then physically compare them to the new ones, if possible.
You have to check the length, width, and the bolt hole, and make sure they are precisely the same. Some blades are high lift type, and some aren't, meaning the cutting edge reverse side is raised to lift the clippings.
/ Bush hog Q #3
Can you post a photo? Most folks here seem pretty good at picking out a model even if it's rough looking.
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
2013 VOLVO ECR88 (A65643)
2013 VOLVO ECR88...
Dragline Bucket (A65640)
Dragline Bucket...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
