Just another junk chainsaw
/ Just another junk chainsaw
@kenmbz did you toss the inside tube and open front up?
Also to help keep fines from getting by the mount area. Oring.
Then small gain by doing this on them. Proven on dyno with stock and then removed.
Really nothing to worry about as my 2 stock 501 I havent done it yet. But did on the ported 490.
I have the oring and did not pull the tube yet.
That's why I was surprised to notice a difference.
Think like 1 more slot and maybe little more open on 501 4910 deflector top.
490 lower.
IMHO still isnt enough. Inside tube pops right out. Open front up.
Echo always hold their saws back by mufflers.
/ Just another junk chainsaw #2,465
Past saws. All ported but the one 365.
No brand loyalty here, they need to earn my trust in the model.
Pick the best from the makers for use.
Even doing that still today.
Ok, going out to Buck Up 2 Cord of 8's. Which Saw would you grab? All having the same Bar and Chain?
Now days lightest saw that will do the job quickly.
Out of those prob the ported 357. I have yet to see a 357 run like that one did.
New off the reel oregon CL so pretty dull. Aspen cant.
/ Just another junk chainsaw #2,467
If I am bucking, I am usually using a 50CC. I have 4 (I think) 50CC saws. The Stihl 261 & 260, Husqvarna 550, and the Echo 4910 that's got a ported muff and squish adjustment. I ALWAYS grab the 4910 first, it's my go to little power house.
Today being I run 325 on the echo 50cc x3 and 3/8 on the 2x 59cc. Wouldnt be same bar or chains used.
I couldnt count in my head how many 50cc-54cc range saws I even have in smaller size ones.
I grab Echo 501 50cc first since super light 50cc, then if bigger got to the ported 359.
Guy from overseas got one too. He playing with his little deeper.
/ Just another junk chainsaw #2,470
Tree work tomorrow. I just packed up the truck. Moving the tractor there tonight. Customer with large fallen tree.
Let’s rock. lol
Getting some ready to go. 346 501 2511
Nothing big so all small saws.
:ROFLMAO: 🍻
KY Lake Lumberjack event
KY Lake lumberjack event info is starting to be let out. Replacing the Murray event I used to love to go to.
3rd weekend in Oct.
Per Melissa and Samuel. =
General Rules
All contestants need to check in at the lumberjack arena and confirm registration and sign a release from before the beginning of the competition. All contestants must be registered to compete and competition will begin at 10:30 a.m.
All timing will done electronically with CMV app. and any times resulting in a tie for any the top places will require a saw-off.
Timing on all chain saw and crosscut events will start when the hands move, and finish when the last piece of wood is severed free from the log. A starters cadence will be used Timers Ready, Competitors Ready, 3,2,1, go.
Leg, hearing and eye protection must be worn in all sawing events.
Event decision are up the discretion of the judge. All judges decision are final.
Underhand Chop
Using a single-bit axe, competitors will chop through a horizontal 8x8 yellow-poplar cant. Cuts are made with the competitors standing on the log and will begin with the starters' signal time will start when the axe hits the wood and end with the log is severed.
Standing Block Chop
Using a single-bit axe, competitors will chop through a vertical standing 8x8 yellow-poplar cant. The contest will begin with the starter signal, time will begin when axe hits the wood and ends when the piece is severed.
Axe Throw
Four throws from behind a line of 20 feet from the target with a bullseye about 5 feet above the ground level. Ladies and children my throw from 15 feet. Score will be best of the 4 throws.
Only one point of the axe in the wood counts. Double Point stick is "no score" for the throw. Point of scoring (by judges) are 5 points for a bulls-eye, 4 points for the next outermost circle,3 points for the next outermost circle, 2 point for the next outermost circle and 1 point for the outermost circle, A cut ine between circles is awarede the higer circle of points.
If a competitors foot hits the ground past the throwing line before the axe hits the wood, that particular throw will receive a "no score"
Ties will be broken by a throw off. The loser of tied score throw off takes over the next scoring place, bumping contestants score along to fill the first five finishing places. Axe should be a double bitted, at least 21/2 pound head with minimum 24" overall handle length, the face of the blade not to exceed 6 inches.
Crosscut Sawing
An individual contestant my enter the crosscut sawing only once in each event. Pieces to be sawn will be 8x8 yellow poplar cants. one line will be saw through the log (Jack and Jill, Jill and Jill and single buck) 2 lines for (two man) Each sawing team may have one "second" or manager. Any chip, slab or "hang" with an uncut end of 1\2 inch or more will cause contestant to receive a no time.
Husqvarna Stock Saw
Chainsaw for the Contest will be provided and adjusted by>>>>>>. The competitor may not adjust the saw in any way. Leg, eye and hearing protection will be provided if needed. The saws will be started and running on ground level and will require three vertical cuts- down, up and down in a 6 inch space marked completely around the log. The pieces will be cut from 8x8 yellow-poplar cants, producing three complete pieces of wood. Time will start when the hands move and end when the third piece is severed.
Stock Appearing
Each contestant may only run once in a class. Saws will belimited to one cylinder, pull start and must be stock appearing (no Over sized mufflers, etc and must have all factory plastic attached) Contestants will supply their own fuel. Saws will be checked for classes and pieces to be cut will be 8x8 poplar cants.
Saws will have a maximin of one minute to be started and warmed up with mechanical adjustments and or malfunctions included. Contest will start with the saws off and resting at ground level with contestant's hand flat on top of the wood with both thumbs touching a line drawn the middle of the piece to be cut.
Three lines will be cut- down,up,down.
The judges will mark a 6" wide area completely around the log and the cuts must produce three complete pieces of wood. Cutouts will cause contestants to receive a "no time"
Leg, hearing and eye protection must be worn. Any contestant not wearing proper protection will be disqualified.
A starters cadence will be used but time will start when the hands move and the Third complete cut is made.
Hot Saw
Saws must be a serial numbered production chain saw engine with any modification allowed. Contests will start with the saws off and resting at ground level with contestants hands flat on top of the wood. The contest will require three vertical cuts down, up and down with in a 6 inch wide space marked completely around the log. The pieces will be cut from a 8x8 yellow-poplar cant. producing 3 complete pieces of wood.
A starting cadence will be used, time starts when hands move on top of the wood and end when third complete piece is severed.
Got the small husky cap to fit down in mag case husky 346 351 353 oil tank. But still not fitting right. Need to file between the cap threads to get better fit.
For those guys that have to have the oil cap as flippy too. IMO not worth the juice since husky makes a nicer oil cap then the 2 prongs I hate.
small and big work on 501 echo with no modding.
Just to show the husky small flip cap can be made to work on the magnesium cased 346 353 351.
Same small cap I use on 2511 with no mods and oil cap 501 no mods.
Grind that area down on cap and grind the threads down to clear them too.
Then file between threads also to gasket.
Fill to top to put extra pressure on it putting in cap.
Clone 2511 cylinder. stihl 200T oem cylinder, echo oem 2511 cylinder
To show transfers.
/ Just another junk chainsaw #2,478
Referencing top handle saws, my Stihl MS192T seems to have a torn boot between the carb and saw ("intake manifold"). Flexing of the handle seems to be the issue is my guess. Curious if anyone knows if Stihl modified the boot to tolerate the flexing?
Common to tear boots on top handles from pulling on them. Not just stihl.
Testing rednecked small flip cap for 2 days. Still no leaking cutting or afterwards setting from oil cap. :cool:
Gas takes big one like 372.
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63118)
2023 Kubota...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2023 John Deere 9RX 640 Track Tractor (A63109)
2023 John Deere...
(3) 295/75R22.5 TIRES (A62131)
(3) 295/75R22.5...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A61165)
2011 Dodge Charger...
