L5740 or some tractor
/ L5740 or some tractor #141
This unit a 2014 John Deere 4044R with 113 hours is still up FS. He seemed motivated when I messaged him. Maybe he'd take 35K? Does need one rear and a front hydraulics added to it
Won't you also need to switch out tires immediately as well or do you plan to run tire chains? This one is located in Indiana.
I think we'd try without to start with. Chain use require those wheel spacers. Some guys claim turf tires do better in snow.
/ L5740 or some tractor #143
Keep in mind that turf tires aren't as tough as R4's for forest work.
/ L5740 or some tractor #144
I've heard people say that, but I don't buy it. Turf tires are designed for the least traction and least damage while mowing lawn-type areas. They aren't really suited for loader work or much of anything else. You can certainly roll around on them, but any other tire would be better for anything other than mowing lawns.
/ L5740 or some tractor #145
There are those that swear by turf tires in snow, but my conditions and experience are similar to yours... Nothing is worse than turf tires in snow.
There is a wide variety of opinions of tire tread styles and snow. Nonetheless, changing tires out sure would be costly.
/ L5740 or some tractor #147
@ArlyA It looks like you have been pondering buying, and asking questions here about tractor purchasing since 2016 but have never pulled the trigger yet. Are you looking for one for yourself or one for your club to use? Have you made the absolute decision to finally buy one or still just pondering the idea?
I don't think I would want to purchase a tractor with the possibility of needing to replace the tires. That would add thousands to the final cost. I would not in any way want turf tires for the intended use you have expressed.
Different purchase and was for a club, they did get a 4045 back in 2016. We are now bidding on a property with acreage.
For sale locally. Note the 3rd function on loader is zip tied on. :LOL: Looked at this unit yesterday and its near new in my book.
2023 4066R, 314 Engine hrs, 30 PTO hrs, 84” snowblower, Skidsteer quick attach loader, HD bucket and forks, Cab with heat and A/C. 3pt down pressure kit, 3rd function to loader, 4th and 5th rear SCV, 3pt accumulator, dual rear wheel weights, rear tires loaded with rim guard. $59,900
After using turf tires that were on the borrowed Kubota I used this summer in mud, I'd not want them.
More pics, he has 2 hydraulic circuits on the back and the extra on the loader, plus power down 3 point. Snowblower barely looked used.
/ L5740 or some tractor #153
Arly- I've looked thru most of this thread but not every post. Do you think you'll want to use tire chains for your snow removal? I have R4's on my L5750HSTC. They suck on snow when bare but are good with chains. If I fit the rear chains just perfectly they didn't rub but it was so close that is was nerve-wracking. So I had to add wheel spacers. They're nice in the summer on side slopes so no regrets. Something to consider....
Dave
/ L5740 or some tractor #155
Dave
I have front chains for the R4s on my L4060hstc. It's been a few seasons since I bothered putting them on. They definitely help & increase my plow capacity. But apparently not enough for me to bother putting them on of the hassle of maintaining them. Not sure if rears would fit or not. I was going to get them if i needed them, but never bothered.
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
Unverferth 432 (A64119)
Unverferth 432...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
