- Joined
- Aug 28, 2012
- Messages
- 25,356
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Well, I’ve had DEF freeze several times.
That’s an owner/operator issue. Can’t blame the truck that DEF freezes. All 2012 and up diesel trucks have similar DEF tanks, pumps and heaters.
That’s other worldly. 7 DEF pumps? That has to be a world record.For the Ram/Cummins fans, the new ones with emissions are not the trucks you’re familiar with. I bought a new one in 2020, and traded it last year for a Ford diesel instead. In the 4 years, and 80,000 miles, it never made it from one oil change to the next without having warranty work needed, about 3/4’s of that was emissions related. I think at the end I was at 6 or 7 DEF pumps, two tanks, the lines for it, an injector and the controller/module was changed out or reprogrammed (maybe both?, trying to forget.) It also had an intercooler replaced, some alternator issue, and body issues with fit and waterleaks.
To the OP, myself for what you’re describing, I’d either redo your current truck if you like the basics of what you have, or look at the Ford godzilla in either a 3/4 or one ton single rear wheel.
Can’t say any of that happened on my 2020.
So far on mine: (1) DEF sensor (truck still ran fine, gauge wouldn’t work), front wheel spindle (I submerged truck in 2’ of water trying to escape a flood).
And I work my truck hard as heck.
By far best truck I ever owned and as of now would buy another in 2027, when the 7.2L Cummins hits, unless Ford or GM fix their issues.
