Help me decide, 3 trucks I need to pick 1 from.
   / Help me decide, 3 trucks I need to pick 1 from. #61
Well that’s false because I drive my Ram 12K per year for 5 years and I haven’t had any such issues whatsoever.
I think what is in your favor is you are working your truck pulling heavy loads often rather than just getting two bags of chips at the grocery store.
These diesel’s need to work enough to get fully warm to avoid issues and you do that and that’s how they’re supposed to be run.
Try to find a good pre-‘18 Dodge with the Cummins and you can tune it unless VA (I suspect) has smog inspection. Fords today are laden with problems. They have the highest amount of issues, and I know this because I belong to two Ford truck web communities. A pre-‘18 Dodge can be tuned for 20+ mpg on the highway. I get that in my dually 3500 CC when I try. The sweet spot for the Cummins is 1900-2000 rpm, which is upper 70’s and where the best unladen fuel economy is. The trucks are so nice on the inside (Laramie) you’ll make it your daily driver. At one time my brother and I owned 13 Fords, so I’m not disloyal, just pragmatic.
Thanks for the detailed reply.
I'm trying to get away from the DIY work because of my aging body. Repairing trucks is not my strong suite. It's also getting difficult to find trustworthy mechanics. I've had 3 great guys for my diesels (1988 7.3L IDI, 2002 7.3 Turbo), 2 of which passed away, one just stopped. So I've been focusing on new or near new for my tow vehicle.
   / Help me decide, 3 trucks I need to pick 1 from. #63
We had 2 days of 10-12 degree weather here last winter. I was also told that when the temps get that low, you should keep the DEF level under 1/2 full. I didn’t realize my DEF tank was 3/4 full. I was worried it would freeze. It never did.
In my 20+ years of being on the internet, I have read more BS rumors that never amounted to anything.
From what I read, that ia right at the freezing point for DEF. Assuming it works like water in that regard, short time right at freezing will not be an issue. Air changes temperature much more quickly than water (and likely DEF, too). I'd guess it's a bigger issue for those who regularly get temps under 12 degrees F (-11 C).
Where I grew up, they average 36+ nights with lows below 0 F. Average low temp in January is 2 F. Up there, I am sure it's a bigger issue.. DEF wasn't a thing back then, though.
   / Help me decide, 3 trucks I need to pick 1 from. #64
Buy a Ram with the Cummins diesel, but not one with 300K miles.
   / Help me decide, 3 trucks I need to pick 1 from. #65
Background:I'm retired. I've been going through the process of trying to determine what truck to add to my fleet. The truck will be used in Virginia and Mississippi. It's prime purpose will be to gather dust and suck up parking space. Occasionally, maybe 5 times a year I'll drive it from Va. to Ms. towing a 10K trailer down I81, I40, I75 and getting to northeast Ms. and then after a month or three, drive back. It will carry 2 passengers, me and my wife.
I've been making this trip with about this frequency since 2011 mostly with a 2002 Ford F350 7.3, CC, dually and it's crazy I know.
But the dually is getting "long in the tooth" and I'm concerned about it breaking down.
I missed out on the deals last January and the Tariff threat kicked in and prices jacked up. But now they have come back down slightly.
Also I looked at 5L F150's and they cost almost as much.
So I've narrowed my choices down to 3 vehicles.
2023 Ram Bighorn with /edit- 6.7L
diesel < 300 miles ~53K
Warranty mostly used up sitting on the lot
2024 Ford F250 XL w/ 6.7 0 miles full warranty ~56K
2025 Ford F250 XL w/ 6.7 0 miles full warranty ~60K
To me the 2024 is the sweet spot.
/edit - what would you pick?
You might consider leasing or purchasing a property in that area as an alternative. IMHO
   / Help me decide, 3 trucks I need to pick 1 from. #66
I am also retired and only drive my diesel 2018 2500 6.7 Ram about 8000 a year. The thing I learned the hard way is the DEF fluid in all the newer vehicles solidifies clogging everything up. I was quoted $7000 to repair mine. Problem is if I fix it, it will just keep happening. You would be better off rebuilding the engine in your 2002. I was told I needed to drive at least 45K to 50K miles a year to keep it from happening.
Or buy an older 6.7L diesel that's been deleted. Then no worry about DEF.
I too only drove my F250 6.7L about 7K / yr. Ended up selling it a few months ago. Came to terms that I don't need a truck and if do I'll just rent one.
   / Help me decide, 3 trucks I need to pick 1 from. #68
On the specific vehicles listed; i do think the Ram Bighorn trim is a sweet spot, of options that are nice to have, vs expensive stuff you'll never use, but still pay for.
   / Help me decide, 3 trucks I need to pick 1 from. #69
Either truck will do the job. If they are selling the Ram as new the warranty won't start until it is registered to the owner. With only 300 miles I would give it a close look. I know it is crazy but I looked at a 2016 Impala that had 40 thousand miles on it. It was a dealer demo and never been titled so they could sell it as new. I am partial to Fords and have a 2012 now that I bought new. It only has 62 thousand on it with the 6.7 engine. As old as I am I hope it lasts another year or two. The Ram will be easier and cheaper to repair. It is totally up to you. The Ford is a totally new design so give that some thought. Let me know which one you get.
   / Help me decide, 3 trucks I need to pick 1 from. #70
None of the above. But then this is mine so I might be prejudiced.
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
