Looking for 24mm or 15/16" pins
   / Looking for 24mm or 15/16" pins #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
My tractor has a folding ROPS that is locked with two clevis pins, I've lost one of them. As far as I can tell they are 24mm diameter. I haven't been able to find a dealer who has a replacement. I tried using a 7/8" hitch pin, it was too small, and a 1" pin was too big. If they are 24mm then 15/16" would be 23.8mm and I think that would work. Length is about 4".
So far no luck in finding anything suitable. Any pointers?
Thanks.
   / Looking for 24mm or 15/16" pins #2
If you come by, I can turn that 1 inch pin down to any size you need on the lathe. Not a simple task, as the commercial pins don't give much material to chuck up on. I bet you could live with a center hole for this application ;-)
   / Looking for 24mm or 15/16" pins #3
24mm is a really odd size. Could they be 25mm which would be 0.98"? That's a common clevis pin diameter you can get from McMaster Carr or Misumi. I'd just turn one on the lathe out of 4140 if it's really 24mm.
   / Looking for 24mm or 15/16" pins #4
get a replacement from the dealer.
The cost will be worth not having the hassle.
   / Looking for 24mm or 15/16" pins #5
Thanks.
McMaster-Carr
My folding ROPS uses the same size your machine has. And it has these McMaster clevis and pin setup.
It could be. A quick google tells me that 25mm pins are available. I'll order some and see.
I measured it, it's definitely 24mm.
Dealer recommended a 24mm bolt. I'd need to figure out a way to keep the nut from rattling off but still make it quick removal.
   / Looking for 24mm or 15/16" pins #9
Honestly, if you have a hand grinder or a bench grinder, just shave a larger one down a bit. Take a few minutes. Wouldnt need a mill.
Or enlarge the hole to a standard size pin.
   / Looking for 24mm or 15/16" pins #10
piece of 15/16 or 24 mm rod weld head on one end drill hole for hitch pin on the other or like stated a bolt depending on what you can find available.
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
