L4802 HYDRAULIC FILTER QUESTION
/ L4802 HYDRAULIC FILTER QUESTION #1
gumshu
JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
It’s time for my 50 hour service for my L4802. The recommended Hydraulic filter (not the HST) is the TC830-37700. However, it costs about $155. That’s just crazy. I haven’t been able to find a cross referenced filter, but wondering if the older HHTA0-37710, used on the older L’s will fit and work… and is there really a difference between the two? I know that John Deere changes model numbers on the same filter and jacks up the price. I suspect that Orange is no different. Thanks
/ L4802 HYDRAULIC FILTER QUESTION #3
Its a scam. You are being controlled by big business using AI to coerce you. Stop wasting money on oil and filters. Stick it to the man. Use the money you save to buy meme coins.
/ L4802 HYDRAULIC FILTER QUESTION #5
I checked... Yes $155.
I would still bite the bullet and go OEM for a hydraulic filter.
I’m just curious to know why the older HHTA0-37710 wouldn’t work. I doubt that the threading has changed.
/ L4802 HYDRAULIC FILTER QUESTION #7
What about the rest? Micron rating? Flow rates? Bypass valve setting? There is a lot more to a filter, specially being on the suction side of the pumps.
There is a chance it could work, but without knowing the factory specs of both filters, it's hard to give a correct answer.
THank’s guys. I just ordered the OEM from my local dealer at $163… for one stinking filter.
