KL4030 loader spring pins
/ KL4030 loader spring pins #1
Blackcatstrat
Member
CT/VT
Kioti CK2610, CK2510, New Holland TC18
Hello all,went to put my bucket on this morning on my Kioti 2610 with the Kl4030 loader and found that one of the spring pins for the detach lever is gone. This connects the release arms to the quick attach pins and also holds that assembly together.
Haven't been able to locate a part number or size and am assuming it's something odd so Tractor supply may not have it.
Was hoping one of you folks may have a diagram for that loader that would show the part number I need.
Trying to avoid the 2 hour round trip to Tractor supply just to find out they don't have it.
Getting that spring stuffed back in there and getting a pin back in doesn't look like it will be fun.
Guess we are going to start drinking early today
Many thanks.
Jerry
Number 6 is the one I am looking for. I called the dealer that I purchased the tractor from and they won't provide a part number.
/ KL4030 loader spring pins #3
I would just measure it and order some from Mcmaster.com
Thank you for the reply, the pin was completely lost so no way to get a measurement. I just ended up going to the dealer and purchased a few of them. Although still no part number I have some spares and can get a measurement now if needed.
Although I have not been a big fan of this tractor it has been decent up until recently. This pin wasn't a big deal but now I have starter strangeness going on and "gear noise" while using the brakes. Of course I only have 10 payments left and its payed for but I'll save all that for another post.
Thanks again.
Jerry
/ KL4030 loader spring pins #5
/ KL4030 loader spring pins #6
Hardware rarely has part numbers. Typically, a parts list will just give the dimensions. You could have taken Part #5 to a hardware store and probably got a match.
