Compact telehandler
/ Compact telehandler #381
/ Compact telehandler #382
2 questions…
Do yall turn the battery off(behind the cab) when you shut the 417 off for extended periods of time? Say 2+ weeks.
Mine is running warm, up to the yellow. Its a 2016 with 319 hours and a recent 250 hr service. Notice it when running the mower, after about 2 hours of mowing it starts creeping up. I have enough radiator fluid and engine compartment is clean of debris. Any ideas? Its too new to be doing this imo.
Thanks
/ Compact telehandler #383
2 questions…
Thanks
I always turn the battery disconnect off on my machines that are equipped. There’s the obvious reason of preventing battery discharge but it also reduces fire risk and unintended usage. Turning the disconnect back on isn’t exactly master mind criminal stuff but a joyriding punk probably wouldn’t know.
/ Compact telehandler #384
No, but that is a good thing to do. I need to do that now since it doesn't get used as much now on the smaller (33 acres down from 80) place we moved to.
I replaced the original battery with an AGM battery 5 years ago.
Blow the dust out of the radiator core: car radiator cleaning air tool - Image Search
/ Compact telehandler #385
This is how I replaced it. Put the V417 up on the trailer:
Removed the old (black) battery:
Set the AGM battery on a bucket:
Slid the bucket in and over:
Shoved the battery up in place and clamped it down:
/ Compact telehandler #386
Xfaxman, what is that metal white box behind the rear tail light on your rig?
/ Compact telehandler #387
It is an old ammo box that someone painted before I bought it.
Use it for chain and strap storage:
And another chain storage spot:
And shovel storage place above the box:
/ Compact telehandler #388
Now thats a great idea!
Re: tire pressure. I had a tire come off the rim and the guy who dealt with it said it was underinflated and messed up the stem(no good anymore).
I had Haulet SKS 14-17.5 14 PR all around(came with them) and they used the Bobcat 17.5 NHS for the replacement.
Everywhere im looking says 80psi for both types.
Is that correct?
Thanks!
Haulet sks wide wall 14-17.5 14PR
/ Compact telehandler #390
Hooked the chain to the tree I pushed over two months ago:
Dragged it out of the woods:
Pulled it to the brush pile:
Picked it up with the grapple:
View from the seat, pulled forward and extended the boom to put it out over the pile:
Opened the dual lids and gravity grabbed it:
/ Compact telehandler #392
Errgh…its still running hot. I get about 30 mins of mowing before its at yellow. Hydrolics start slowing down. Turning off AUX keeps it from getting hotter. Plus/minus on running the AC as far as temp influence. I hate to have someone check it out.
Last time they found a “leak” in the gas tank and had to replace it-took them a year to get it back to me bec of Covid supply issues, meanwhile it sat outside uncovered for a year(i keep all my equipment covered). Anyways, if i can figure it out itll save me from them getting it.
Any other ideas on why it would be running hot?
Thanks!
/ Compact telehandler #394
I blew out the radiator, oil condensor, and the silver condensor i assume is for the AC.
It did help some-more non running hot time. Though the heat index is 100F, i just thought it wouldnt be give me this kind of trouble
Do you think i need to do a radiator flush?
If so, i think the radiator plug is underneath, right?
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
BLANTON 13' DRAG HARROW (A63745)
BLANTON 13' DRAG...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
Club Car (A59231)
Club Car (A59231)
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
