PTO operating while off the tractor
/ PTO operating while off the tractor #1
chief 83
New Holland Workmaster 84
I guess I don't know how to search properly as I'm sure this has been asked before. I have a 2023 Workmaster 75 open station tractor. I don't know how to keep the pto engaged while off the tractor. I have a small pto button on the dash that I think has something to do with it but I don't know the sequence or something. To engage the pto I have a handle to the left of the seat that you pull up to engage. That works fine. But I'd like to get off on occasion to check the baler etc while it is running. So far I've not been able to do that. Help.
/ PTO operating while off the tractor #2
It should be covered in your operator's manual. If you don't have one it would be a good idea to get it. You probably can download it for free.
/ PTO operating while off the tractor #3
On my MF I have the gearbox in/out lever by the seat and a 'dial' type switch on the dash to engage the pto. I disabled the seat 'safety' switch so I can get off when I want but on the rear fender is a small button to engage the PTO when you're off the tractor but for it to work the shift lever (hydro) has to be in neutral and the park brake set then hold the button for 3 seconds. Shuts off immediately with a second push.
I have one and have read it. It says push the button...which I have done. New Hollands manual is probably the worst one I've had. Covers multiple tractors and really when it comes to the PTO doesn't have info on the style I have.
/ PTO operating while off the tractor #5
Not the same brand, but my Kubota requires that I be in the seat, engage the pto, get off the seat and raise the seat within a second or two (activating a second switch).
Have you tried getting out of the seat first, then immediately pushing the unattended pto button?
/ PTO operating while off the tractor #6
I wired the switch open on my Kubota because I got tired of it shutting the tractor off everytime I turned in the seat to look at the tiller, mower, harrow or whatever I was doing. I'm all about safety (which is why my first suggestion was the manual) yet they also need to be practical.
/ PTO operating while off the tractor #7
All these safety switches; society assumes we must be protected from ourselves. The people making these decisions likely have never farmed or been on one.
/ PTO operating while off the tractor #9
Never as been an issue with my Ag-Utility Kubota's. I can leave the pto engaged and get off the tractor at will and I use it when I'm running my grain leg as I have to be watchful about how the leg's bin is filling.
/ PTO operating while off the tractor #10
MY Massy GC1715 requires me to be in seat... I actually put ZIP tie around seat switch and since tractor is "dumb" it thinks I'm still on seat....
/ PTO operating while off the tractor #12
Mine works on my WM75. You must be sitting in the seat, PTO engaged. All three gear levers must be in neutral and the parking brake set. Push the button, you will see the PTO indicator change to a grey box background. You can then exit the seat and the PTO will stay engaged. When you sit back down the PTO indicator will go back to normal operation. Get out of the seat again and the tractor will die.
/ PTO operating while off the tractor #14
That's exactly how the kill override button works on my Powerstar tractors.
And from what I understand, it doesn't keep running indefinitely, as it has a time limit. Not tested the time limit, but that's what I was told.
/ PTO operating while off the tractor #15
You're not alone the PTO run feature on the newer Workmasters can be a little confusing at first. On your 2023 Workmaster 75, that small button on the dash is indeed key to keeping the PTO engaged when you're off the seat.
Here’s the general sequence:
Start the tractor and engage the PTO using the lever beside the seat like you normally do.
Before leaving the seat, press and hold that small PTO button on the dash until the PTO light starts flashing (usually takes about 5 seconds).
Once the light is flashing, you can safely get off the tractor and the PTO will continue to run.
This is a stationary PTO feature, meant for use when you're off the tractor but the machine is stationary like when checking a baler or running a grain auger. If you try to move the tractor or do anything else while off the seat, it’ll kick the PTO off.
If the light doesn’t flash or the PTO shuts off when you stand up, check that your seat switch is working properly — if the tractor thinks you’re off the seat prematurely, it won’t let the sequence complete.
Hope that helps!
/ PTO operating while off the tractor #17
Not it.
The ppl making these decisions, are more concentrative on litigation and has nothing to do with the concern of safety.
Anyway of mitigating the aspect of factory “negligence”, governs this mindset.
/ PTO operating while off the tractor #18
Yeah and my pop was a pediatrician in farm country. Most deaths or limbs cut off happened to kids on tractors. Safety 1 2 3 I wouldn't defeat safety switches. They are there for a reason. People to dumb ****. I have a cab tractor and a long driveway. I was driving down my driveway with a speed bump at 20mph and forgot about the speed bump. Had I not had a cab I would have been ejected and my tractor would have landed in the woods. The PTO engaged while your not in the seat .... yeah thats not a thing and why there's a safety switch so you cant do that. What implement do we use that requires the operator to not be seated??
/ PTO operating while off the tractor #19
My John Deere compact 4320 has 2 settings for the PTO's. Mid and Rear combined and then Rear only. In the Rear only setting I can set the parking brake and then dismount the tractor with the Rear PTO engaged. I use this setting for running my PTO driven wood splitter. With the Mid and Rear engaged the seat switch shuts off the PTO's. aka using MMM. Just some info.
/ PTO operating while off the tractor #20
In my case, the logging winch and backhoe. Formerly also a wood splitter, hopefully a wood chipper in the future.
Yet as I mentioned before, I disabled my seat switch because I got tired of it shutting the tractor down every time I turn in the seat to watch the mower, tiller, plow or disc harrow.
2026 Electric Tricycle (A64194)
2026 Electric...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
