Rainwater System / cleaning equipment and garden watering
/ Rainwater System / cleaning equipment and garden watering #1
brewdog
Gold Member
NW PA
LS MT 225s, New Holland 3040, Kubota Z 422 - 60"
I bought this 1100 gallon tank 2 years and finally got around to installing it. The water will be used mainly for watering the garden and cleaning up my equipment. Its a simple system with a Special Pump from Rain Brothers in Ohio. The pumps does not require a pressure tank and pressure switch. The control logic is contained inside the pump. When you open the spigot the pump senses the loss of pressure and starts pumping. When you shut the spigot off the pump senses the increase in pressure and shuts off. I mounted it in the tank with a pit-less adapter like you would use in a deep water well. There was a 1/4” of rain yesterday and the tank filled to about 4” or close to 100 gallons.
/ Rainwater System / cleaning equipment and garden watering #2
Nice set up just curious why you installed it. Remote building not served by well or town water ? Save money on town water, reduce wear and tear on well pump ?
/ Rainwater System / cleaning equipment and garden watering #3
What kind of water pressure does it produce? I could see this being an option for my drip irrigation. Gonna look them up. Thanks for the idea.
/ Rainwater System / cleaning equipment and garden watering #4
I use a HF 110 volt mini water pump with my IBC totes. That provides ample pressure to feed my triplex pump on my pressure washer. The pump is mounted on the pressure washer cart and is plugged into an outlet in the shop with a GFCI connector. Problem with rainwater collection is straining out the junk that collects in the gutters so I use a screen at the gutter terminis and drail the flush the totes regularly. A good rain event will completely fill both of my 350 gallon totes in one shot. I also add a coup,e ounces of H2O2 to each tote to eliminate any 'green' matter in the tanks and the tanks are covered with black film glued on to prevent sunlight from growing algae. At least 4 years now and zero issues. I do drain them in the winter so they don't turn into huge ice cubes.
/ Rainwater System / cleaning equipment and garden watering #5
Wish I had done a few things differently. I put in a 1500 gal underground cistern, fed from the garage roof. This is plumbed to a centrifugal pump to all the hose bibs around the house. Its not connected to the domestic well. 1500 wasn't near enough for my climate and all the gardens around the house we created. It rains like heck all winter and then just a little in late spring, and then NOTHING for three months in the summer. If to do, a do over, I'd put in some huge above ground tanks, 4500 gal or so, hidden behind the garage, out of sight and sunlight, and have that metered by temperature in some way, to automatically gravity feed drip lines to the gardens. As it is now, my summers are taken up by me manually watering these gardens every other week mid-summer. And then trying to balance how much water I want in reserve for possible summer fire control.
I never have enough water, aside from the winters, when I have way too much.
I guess the take away here, is even though I've lived here for 35 years, I really didn't understand the climate of the PNW. Its on with rain in the winters, and then its entirely off in the summers. So you need a huge water bank to smooth that out.
Great question. I do have spring water from my underground tank in the pole barn, but I don’t like using the spring water for washing equipment and watering the garden during the summer months because we use it in our home as the primary water supply. I try to conserve water during the summer months when the spring is running slower. We have no city water where we live.
I get about 60psi from the system but they don’t recommend using this type of pump for drip irrigation system. They recommend a system with a pressure tank and pressure switch. I bought mine from Rain Brother in Ohio. Great question good luck.
Great information you provided. Thanks I use this device for filter the junk out. It works automatically but I don’t have long term experience with it. One half of my Pole Barn is 22’ x 40’ long with one downspout and it filled by tank to 800 gallons is 3 days of intermittent but heavy rains during the last few days. Thank you for the great information ! I was planning on draining my tank this winter too.
Really interesting how much different things are in the PNW. We have had dry periods but those seem rare in this area. Hopefully you can add another large tank to your property. Good luck and thanks for the interesting post.
/ Rainwater System / cleaning equipment and garden watering #10
I’ve considered doing something similar. I have a 400 ft well super hard water and slow recovery that I’m nervous to use for any type of irrigation or heavy usage. There are 2 other hand dug wells from late 1700s that pretty much dry up every summer. So something like yours with a pressure tank might be the best solution.
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
