Rotary Cutter Bush hog Model 2[emoji[emoji6[emoji640]2][emoji640][emoji640]][emoji6[emoji640]2] Deck Repair
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #12
I think you are in for an exercise in futility with a 110v wire feed. First thing is to make sure you have the correct type of wire.
I was doing small repairs on a brush hog welding cracks with my small wire feed and they'd just crack again in a matter of days. The welds were just breaking/cracking.
My pro welder friend told me it is the wire I am using. I forget exactly what he said, wire too hard/soft, something like that, and I never followed up with him on it. For a successful job I think you'll need to get all the prep done and get a friend with a bigger welder to come help out!
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #13
View attachment 3579020View attachment 3579021View attachment 3579022View attachment 3579023View attachment 3579024View attachment 3579025
As the photos show, my deck is in bad shape. This cutter is 20 years old and when the rust/rot started it took hold fast. I have acquired some steel plate 1/8” to make the repairs. What is the best option to cut it? I do not have access to a torch, but do have a grinder with metal cut off wheels and can get my hands on a port a band. Thoughts? Any further advice on repair is definitely appreciated. Thanks
Get yourself a metal cutting blade for a circular saw. I’ve cut 1/4” metal with one with ease.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #14
I burned my skilsaw up using one of those.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #15
Can’t force them.
I would limit a circular saw to 1/8 sheet material due the length of the cuts.
For something like 1.5” strap I would likely do 1/4” thick.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #16
Technique is everything. Saw set depth is another.
Also the quality of the saw.
The 8.25” Milwaukee I have goes thru metal like butter but it’s built to bury an 8.25” blade.
I don’t know if they even make this saw anymore.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #17
Take it to a shop with a plasma cutter and remove ALL the panels. Cut new ones to suit.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #18
Another vote for 4 1/2" grinder with thin cut-off disk. Ever since "Project Binky" (on U-tube), I've been impressed how much can be done with that tool. I've also done the saber saw, cutting torch, saws-all mentioned by others, but those are much slower. like chim, I make multiple passes to grind through the thickness, the first being mostly to set the line of the cut and rest to remove metal.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #19
Would it be worth while to take the cutter to a metal fabrication shop and have it re-decked? Then when you get it back, you can prime and paint it yourself.
Unless it has sentimental value, I would sell it for what I could get for it and go buy another cutter, depending on what it would cost to have it re-decked.
I had a Bush Hog 285 many years ago and it was an absolute beast.
Being the welder I have is light duty, I may go this route. No sentimental value, just an equivalent bush hog is 3k, not really in the budget.
Zero Turn Mower (A48082)
Zero Turn Mower...
2007 Ford Escape AWD SUV (A48082)
2007 Ford Escape...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2010 Toyota RAV4 Limited SUV (A48082)
2010 Toyota RAV4...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
1261 (A50490)
1261 (A50490)
