- Joined
- Feb 21, 2003
- Messages
- 26,957
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
I'm not that cheap. I'd scrap that turd and buy a new one....
Get yourself a metal cutting blade for a circular saw. I’ve cut 1/4” metal with one with ease.View attachment 3579020View attachment 3579021View attachment 3579022View attachment 3579023View attachment 3579024View attachment 3579025
As the photos show, my deck is in bad shape. This cutter is 20 years old and when the rust/rot started it took hold fast. I have acquired some steel plate 1/8” to make the repairs. What is the best option to cut it? I do not have access to a torch, but do have a grinder with metal cut off wheels and can get my hands on a port a band. Thoughts? Any further advice on repair is definitely appreciated. Thanks
I burned my skilsaw up using one of those.Get yourself a metal cutting blade for a circular saw. I’ve cut 1/4” metal with one with ease.
Can’t force them.I burned my skilsaw up using one of those.
Technique is everything. Saw set depth is another.I burned my skilsaw up using one of those.
Take it to a shop with a plasma cutter and remove ALL the panels. Cut new ones to suit.View attachment 3579020View attachment 3579021View attachment 3579022View attachment 3579023View attachment 3579024View attachment 3579025
Would it be worth while to take the cutter to a metal fabrication shop and have it re-decked? Then when you get it back, you can prime and paint it yourself.View attachment 3579020View attachment 3579021View attachment 3579022View attachment 3579023View attachment 3579024View attachment 3579025
Unless it has sentimental value, I would sell it for what I could get for it and go buy another cutter, depending on what it would cost to have it re-decked.
I had a Bush Hog 285 many years ago and it was an absolute beast.
