YT359 Question
/ YT359 Question #1
AuCivil
Alabama
JD4710
Trying to gather information before my final purchase decision. While going down a slope does the YT359 hold in "shuttle shift" neutral without brakes like a hydrostatic does with the foot off the pedal?
/ YT359 Question #2
It holds better than a hydrostatic transmission. When a hydrostatic transmission is overloaded (pressure over relief) on a hill, it will start to move rapidly. Due to the method the i-HMT works, it holds with little more than a creep.
/ YT359 Question
Thanks for the info. I get the creep while in fwd or rev but if you put the fwd-N-rev shuttle lever in Neutral does it free wheel or hold.
/ YT359 Question #4
It will free wheel when in N or when the clutch is pressed. You can stop in forward or reverse by simply pressing the brake. The clutch can be used as an inching pedal or to help disconnect implements by relieving pressure.
/ YT359 Question
Thanks
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
EZ Trail 3400 (A63118)
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
