/ Share Pics of People Hauling or Towing Something Wrong #22,601
This is what UPS did with a package for me a few days ago.,
Shipment Details
You’ve Got the Details
You’re seeing what customer service agents would share with you. If you need more support,
use the Virtual Assistant or contact your shipper.
I can break this down with 95% accuracy as to what happened. The facility I work at the beginning and the end for packages. We are small and everything is done manually with human mistakes. The larger facilities are much larger and automated sorting. I recently worked an evening(Local Sort) and saw what happens at the beginning of a packages travels. Rest of the time I'm working mornings loading trucks for delivery(Preload).
From our facility 2 trailers leave. One for Buffalo, NY and one to New Stanton, PA. I have watched my own packages and it is interesting as you learn from the inside how things move.
Anybody reading this start at the bottom of the quotes to follow this packages journey.
 Times shown are in Local Time Change
06/02/2025
12:00 P.M.
Delivered
DELIVERED
GREENWICH, NY, US
Finally you have received your package that left you were wondering how in the world is it possible for it to travel the way it did. Imagine it getting on a different trailer yet...............................
06/02/2025
7:18 A.M.
Out for Delivery
Out For Delivery Today
Latham, NY, United States
Driver has been released and the truck is on the road.
05/31/2025
6:14 P.M.
On the Way
Processing at UPS Facility
Trailer is being unloaded and some nit wit like me is sweating their balls loading packages on a delivery truck. Only they are doing it in the evening where we do it in the morning.
05/31/2025
3:20 A.M.
Arrived at Facility
This is correct. Trailer arrived
05/30/2025
10:32 P.M.
Departed from Facility
Buffalo, NY, United States
Trailer released
05/30/2025
2:29 P.M.
Arrived at Facility
Mansfield to Buffalo is correct. Trailer arrived and unloaded and packages split pending loacation.
05/30/2025
9:03 A.M.
Mansfield, OH, United States
Trailer released.
05/30/2025
8:28 A.M.
Arrived at Facility
This is correct and a main hub. Trailer arrived and unloaded. Packages split to other trailers pending location.
05/30/2025
4:12 A.M.
Lexington, KY, United States
Trailer released and package is back on track.
05/29/2025
5:32 A.M.
4 Possibilities here.
1. Driver grabbed the wrong trailer and the whole trailer was supposed to go in a different direction.
2. It got scanned in Kingston and either mechanically or humanly was sent to the wrong trailer
3. If larger facilities do this and if it was a small package it was put in a bag. The bag is affixed with location sticker, then it is scanned before loaded on the wrong trailer.
4. If small package it could have been put in the wrong bag but the bag itself is correct.
All of these scenarios would have been corrected here.
I believe Lexington is a very large hub. We have what are called pass through trailers that get dropped at our facility. Then another driver delivering a trailer will pick it up and continue it on its way. Know of one that was bound for Kentucky in the past.
05/29/2025
4:38 A.M.
Kingston, NY, United States
Keep in mind I can only speculate. Trailer was released. The next timestamp above is KY. Highly unlikely that package was supposed to go there. I don't know where Kingston, NY is in relation to Buffalo but I suspect the package was supposed to go from Kingston to Buffalo. Each of these stops are considered main hubs where trailers are unloaded and sorted to other trailers to continue their journey as well as deliver to their local region. Each of these transitions open you up to a mistake whether human or mechanical. But everybody wants to blame the big bad company. Like non of use ever made a mistake.
05/29/2025
3:24 A.M.
Arrived at Facility
Trailer arrived and unloaded packages split to other trailers pending location and here is where things get goofy.
05/28/2025
10:55 P.M.
Middletown, PA, United States
Trailer released.
05/27/2025
11:27 P.M.
Arrived at Facility
Trailer arrived and was unloaded. This is a main hub. Packages were split to other trailers pending location either mechanically or manually.
05/27/2025
9:31 P.M.
Baltimore, MD, United States
Trailer has been released
05/27/2025
8:52 P.M.
Arrived at Facility
In our facility this is local sort. This time stamp indicates that it has been loaded on the trailer.
05/27/2025
3:17 P.M.
We Have Your Package
Pickup Scan
UPS driver picked it up toward the end of his day and it is now on the truck that started its day delivering packages.(I have not seen this process)
05/26/2025
7:23 P.M.
Label Created
Shipper created a label, UPS has not received the package yet.
United States
From MD to PA to NY to KY to OH to NY and then finally to me.
The company you purchased from created the label. Self explantory.
/ Share Pics of People Hauling or Towing Something Wrong #22,602
That's one of the oddest shipping mishaps I have ever heard. Break open your package and add more to it. Wild.
And I needed one post to hit 5000, because I wanted to see what that was like. 😁
I once had an empty package delivered. It was obviously broken open and nothing in it. I guess the driver decided it was easier to make it my problem than his.
Congratulations on 5000.
/ Share Pics of People Hauling or Towing Something Wrong #22,603
I work for a big company that ships and receives parts on an almost daily basis. Much heavier on the receiving than shipping but we do both. An issue we regularly see in addition to the parts mishandling by the carrier is shipments being dropped off by the driver without notifying the consignee. Also, any parts that have our company name (Typical packaging and not our address) on the box are likely to be dropped off if we do not adamantly tell the driver to check the shipping documents. Our company fails to adequately package goods for truck shipment but the carriers during the recent few years have dropped to a level of service unheard of a few years ago. All of the automation in tracking has not improved the level of service we typically see today.
/ Share Pics of People Hauling or Towing Something Wrong #22,604
Not to excuse UPS, FEDEX, etc., etc. but a large part of this not just in routing of deliveries but transportation in general is John Q. Public. Most everyone wants everything instantly, hence the pressure to deliver.
I drove LTL for awhile both local and line haul. The pressure on the dock workers to unload/load trailers is nothing short of organized chaos. Out on the road, ***t happens. A truck sitting in traffic for even just a few minutes can throw a monkey wrench into everything.
Think about how far we have come since the days of sending a check for something. Then the check would have to clear before whatever was shipped. All done by snail mail.
/ Share Pics of People Hauling or Towing Something Wrong #22,605
:ROFLMAO::ROFLMAO::ROFLMAO:
Fastest is about 4 days for anything from Amazon, and it has gotten slower lately and here's why. USPS does not deliver packages to individual homes or mailboxes in the area where I live. They deliver to their own "banks" of mailboxes which are a few miles apart. Each individual "mailbox" is just a slot perhaps 12" by 18" deep - but only about 2" high. So not much besides an envelope can be put in those and if a package is shipped USPS, when it arrives we get a slip in our mailbox telling us to drive to town to pick up our package.
I live outside of town and my mail is delivered to one of those mailbox banks. But we also have two USPS parcel lockers next to the mailbox. They are pretty good sized and when a package is sent, the postman puts a key to the locker in your box. It might be worth checking to see if you could get one,
Doug in SW IA
/ Share Pics of People Hauling or Towing Something Wrong #22,607
I had a way to prevent vendors from using Fed Ex, I would, just to keep their drivers off our property and out of our neighborhood. Unfortunately, some vendors default to them, and so they're not entirely avoidable
I feel the same way. If there is any way to screw up, their Connecticut facility will do it. A few years ago I ordered plant material from a company somewhere past New York. It took over 2 weeks to get here; by that time it was dead. I should have asked for a full refund, but thought I could salvage some of the order.
I was wrong.
It didn't matter because a couple of months later they sold out to a big chain and my store credit was gone.
Some of the local drivers are good here. Some aren't. Last month I ordered a turntable. I finally recieved notice it was delivered but when I got home it was gone. The likelyhood of somebody beating me to it was slim...the likelyhood of somebody driving past my house in the 2 hours between dropoff and me getting home are almost none.
About 3 hours later I recieved a call from somebody who lives 40 miles away in a very remote area; he had my package. Apparently he has a dry place for them to leave things and is accustomed to doing the final delivery.
/ Share Pics of People Hauling or Towing Something Wrong #22,608
We ordered some limited edition sheets of stained glass, which is a routine thing for us. When we received the box it looked in bad shape and was very heavy, which is quite unusual. Seems along the way an employee at a FedEx facility cut open the box and stuck a John Deere front wheel adapter and an envelope with an antique license plate bracket in the box, both with shipping labels clearly showing they were not coming to us or even to the same town for one and a different state for the other. They then taped it back up and sent it along the way. Needless to say, the glass was destroyed. Called FedEx, they didn't seem to care. Called the glass supplier, they said it was not unusual and would sent us replacement glass at no charge, once it was back in stock. We notified the other 2 recipients that we had their packages and would return them to where we ship everything out so they could get back into transit. I did follow up to make sure they got their packages. The guy's tractor was broke down in the field waiting on the adapter. Seems like it was hard to find, coming from a dealer in PA to the customer in TX.
View attachment 3559674 View attachment 3559676 View attachment 3559677
I had to have our deere vendor (largest deere engine builder in the states) do a dealer search for a belt i needed.
Deere didn't make the belt anymore. And I didn't have the original to take to the auto parts store to find a gates alternative.
The only dealer that had one, was a little mom and pop store in rural Kansas.
I called them, explained my situation, gave them a credit card number over the phone. They shipped me the part and emailed me a copy of the invoice
Before installing the belt, I went over to the auto parts store and got a gates equivelant as well.
/ Share Pics of People Hauling or Towing Something Wrong #22,609
You might do well to post the equivalent Gates number here, both for your own future memory, and the benefit of anyone else hunting that NLA part.
/ Share Pics of People Hauling or Towing Something Wrong #22,610
That belt was on a JD4045 diesel engine powering a water pump.
We've since sold off those pieces of equipment.
That was several years ago. For a few of them, I wrote on the box with the part number what it was for, and stapled it to the front of the shelf where I kept my JD belts
I wrote the engine model number on empty filter boxes and put them back in my filter cabinet at work for engines where I only have a couple in my fleet.
Especially for the few that are hard to cross the filters over to Baldwin or Wix filters.
My doosan Forklift was that way. Doodan changed their filter number for the forklift, and the old filters i bought from them wouldn't cross to either.
My last trip over to doosan, took them a 1/2hr to cross the old filter number for those filters to a working number in their system.
I was able to cross the new filters to Wix and Baldwin.
Yanmar was bugger to cross as well. The local Yanmar equipment dealer (Their tech) was able to give me the Napa numbers for those filters, and that's when I started saving the boxes since the yanmar number wouldn't cross
At least any of us could look in the cabinet and figure out what they needed for filters since I still only have a small number of those engines in my fleet.
/ Share Pics of People Hauling or Towing Something Wrong #22,611
I deal with both almost every day, running a small manufacturing business from our rural residential / farm-zoned property. On the phone or web, Fed Ex is easier and more helpful, but employs drivers who are just absolutely terrible.
I've dealt with probably 20+ different UPS drivers in my working life, having always worked in manufacturing with lots of goods going in/out, and they've all been very professional and very good at their jobs. On the flip side, the Fed Ex drivers I have to deal with are almost consistently sloppy, disgruntled, and downright reckless drivers.
If I had a way to prevent vendors from using Fed Ex, I would, just to keep their drivers off our property and out of our neighborhood. Unfortunately, some vendors default to them, and so they're not entirely avoidable.
FedEx ground is contract drivers, usually lots of turnover. The quality of driver is typically based on how good the contractor is.
/ Share Pics of People Hauling or Towing Something Wrong #22,612
Yanmar was bugger to cross as well. The local Yanmar equipment dealer (Their tech) was able to give me the Napa numbers for those filters, and that's when I started saving the boxes since the yanmar number wouldn't cross.
With a couple of 45 year old Yanmar tractors that were sold here before Yanmar departed the US for a decade, information can be sparse. The 'new Yanmar' dealers don't have the old manuals or carry the parts.
Ebay listings can be a good place to learn what filter, starter, etc goes with what. In the extensive listings where some vendors list every model, or engine, that their part fits along with the Wix, Baldwin, or Deere equivalent.
But TBN's Yanmar (classic) forum is where the most accurate answers are found for this specialized topic.
/ Share Pics of People Hauling or Towing Something Wrong #22,613
/ Share Pics of People Hauling or Towing Something Wrong #22,614
/ Share Pics of People Hauling or Towing Something Wrong #22,615
No rear wheel spinning?
Bruce
I guess it wasn't all wheel drive after all? Or maybe the passenger side rear tire is spinning that we cant see
/ Share Pics of People Hauling or Towing Something Wrong #22,616
That Subaru on the beach has to have transmission damage. They are all front wheel drive with transfer case clutches engaging instantly any time a front wheel's rpm differs from the the rear wheels.
And back to towing failures!
After a tree fell on this Trooper I bought a '99 Subaru Outback. I assumed the Outback could climb this rocky grade out of our mining claim pulling the little 4x4ft trailer, but no. Picking a line where it wouldn't bottom the $Thousand exhaust system, put it on rocks where one or more tires were hanging in air. No diff lock. I had to back down carefully and ask my buddy to tow the trailer out with his Jeep.
pic00516claimdriveway99-jpg.316887
/ Share Pics of People Hauling or Towing Something Wrong #22,617
Well no pic
but I have a story
A cautionary tale, some would say
I was pulling a flatbed earlier today, with a bunch of wood on it (consider it lumber, mostly)
Trailer popped off the ball, hit a small berm and dumped its load.
Snapped 3k straps like nothing, load all over.
Good: nobody hurt. Trailer 98% ok; needs a new trailer jack; the lumber stuff also 98% ok. Landed in bushes and soft dirt; I was probably going about 30mph at the time.
Bad: I'm a frikken idjit, like wtf. I can try to blame it on a lousy night's sleep, but the truth is I just completely skipped over the consideration that though it was a lightweight flatbed, it still had a 2 5/16" coupler, and I had a 2" ball on my truck from moving my small enclosed cargo trailer last time I used it (months ago). I just completely didn't consider ball size at all.
Starting to think I need a literal checklist for simple things....
/ Share Pics of People Hauling or Towing Something Wrong #22,618
Well no pic
but I have a story
Don't expect to get the cherry for this one. I have seen people do it intentionally because they didn't have the proper ball. (Usually 1 7/8 ball with 2" hitch.)
One person I know of was cutting cedar, loading it onto his trailer and hauling it with a Toyota SR5. The load weighed more than the truck. When somebody offered to let him borrow the correct ball, he declined.
/ Share Pics of People Hauling or Towing Something Wrong #22,619
The newer Fords do have a checklist built into the infotainment systems. It activates when you plug in a new trailer. I'm not sure if there is an option to check ball size though. I skipped over it the last few times, so checklists are only good if you use them.
/ Share Pics of People Hauling or Towing Something Wrong #22,620
GM has the checklist for trailering as well. You can add custom items like check ball size. At first I was not using it and overlooked some things like putting in the lock pin on the bumper pull hitch. I now use it as well as chaining the pin to the tongue to remind me that it is there. It takes longer to do the pre-trip inspection but it is well worth it.
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
2023 CATERPILLAR 299D3 SKID STEER (A62129)
2023 CATERPILLAR...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Mower King...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
