LHF2019
- Joined
- Aug 25, 2021
- Messages
- 942
- Location
- NWPA
- Tractor
- IH1586, JD2350, JD2355, JD2950, JD4040, JD4430, TD95D
I can break this down with 95% accuracy as to what happened. The facility I work at the beginning and the end for packages. We are small and everything is done manually with human mistakes. The larger facilities are much larger and automated sorting. I recently worked an evening(Local Sort) and saw what happens at the beginning of a packages travels. Rest of the time I'm working mornings loading trucks for delivery(Preload).This is what UPS did with a package for me a few days ago.,
Shipment Details
You’ve Got the Details
You’re seeing what customer service agents would share with you. If you need more support,
use the Virtual Assistant or contact your shipper.
From our facility 2 trailers leave. One for Buffalo, NY and one to New Stanton, PA. I have watched my own packages and it is interesting as you learn from the inside how things move.
Anybody reading this start at the bottom of the quotes to follow this packages journey.
Finally you have received your package that left you were wondering how in the world is it possible for it to travel the way it did. Imagine it getting on a different trailer yet............................... Times shown are in Local Time Change
06/02/2025
12:00 P.M.
Delivered
DELIVERED
GREENWICH, NY, US
Driver has been released and the truck is on the road.06/02/2025
7:18 A.M.
Out for Delivery
Out For Delivery Today
Latham, NY, United States
Trailer is being unloaded and some nit wit like me is sweating their balls loading packages on a delivery truck. Only they are doing it in the evening where we do it in the morning.05/31/2025
6:14 P.M.
On the Way
Processing at UPS Facility
This is correct. Trailer arrived05/31/2025
3:20 A.M.
Arrived at Facility
Trailer released05/30/2025
10:32 P.M.
Departed from Facility
Buffalo, NY, United States
Mansfield to Buffalo is correct. Trailer arrived and unloaded and packages split pending loacation.05/30/2025
2:29 P.M.
Arrived at Facility
Trailer released.05/30/2025
9:03 A.M.
Mansfield, OH, United States
This is correct and a main hub. Trailer arrived and unloaded. Packages split to other trailers pending location.05/30/2025
8:28 A.M.
Arrived at Facility
Trailer released and package is back on track.05/30/2025
4:12 A.M.
Lexington, KY, United States
4 Possibilities here.05/29/2025
5:32 A.M.
1. Driver grabbed the wrong trailer and the whole trailer was supposed to go in a different direction.
2. It got scanned in Kingston and either mechanically or humanly was sent to the wrong trailer
3. If larger facilities do this and if it was a small package it was put in a bag. The bag is affixed with location sticker, then it is scanned before loaded on the wrong trailer.
4. If small package it could have been put in the wrong bag but the bag itself is correct.
All of these scenarios would have been corrected here.
I believe Lexington is a very large hub. We have what are called pass through trailers that get dropped at our facility. Then another driver delivering a trailer will pick it up and continue it on its way. Know of one that was bound for Kentucky in the past.
Keep in mind I can only speculate. Trailer was released. The next timestamp above is KY. Highly unlikely that package was supposed to go there. I don't know where Kingston, NY is in relation to Buffalo but I suspect the package was supposed to go from Kingston to Buffalo. Each of these stops are considered main hubs where trailers are unloaded and sorted to other trailers to continue their journey as well as deliver to their local region. Each of these transitions open you up to a mistake whether human or mechanical. But everybody wants to blame the big bad company. Like non of use ever made a mistake.05/29/2025
4:38 A.M.
Kingston, NY, United States
Trailer arrived and unloaded packages split to other trailers pending location and here is where things get goofy.05/29/2025
3:24 A.M.
Arrived at Facility
Trailer released.05/28/2025
10:55 P.M.
Middletown, PA, United States
Trailer arrived and was unloaded. This is a main hub. Packages were split to other trailers pending location either mechanically or manually.05/27/2025
11:27 P.M.
Arrived at Facility
Trailer has been released05/27/2025
9:31 P.M.
Baltimore, MD, United States
In our facility this is local sort. This time stamp indicates that it has been loaded on the trailer.05/27/2025
8:52 P.M.
Arrived at Facility
UPS driver picked it up toward the end of his day and it is now on the truck that started its day delivering packages.(I have not seen this process)05/27/2025
3:17 P.M.
We Have Your Package
Pickup Scan
The company you purchased from created the label. Self explantory.05/26/2025
7:23 P.M.
Label Created
Shipper created a label, UPS has not received the package yet.
United States
From MD to PA to NY to KY to OH to NY and then finally to me.
