Skidder or Tractor? If you could only have one.
/ Skidder or Tractor? If you could only have one. #1
fidowanttobe
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
G'mornin.
I get asked when I will buy a skidder, usually by skidder folk. I say never and that I don't need one cuz of my tractor w/FEL and they look confused. Or wounded?
While I realize that seeing the cutting edge would be a huge advantage, I feel that a tractor is far better for rural living.
Your opinions??
/ Skidder or Tractor? If you could only have one. #4
Tractor, far more practical for me.
/ Skidder or Tractor? If you could only have one. #7
Skid steer will do everything a tractor will do. It just costs three or four times as much to do it.
Really though, there are things the skid steer is better suited for. But the ones that always say "you should get a skid steer" are either very well off and can afford the extra cost or they can't afford to pay attention and just want you to think they have all the answers.
/ Skidder or Tractor? If you could only have one. #8
Hard to beat a tractor for number of uses you can put it too. Especially if you have skid steer type quick attach FEL (able to change out attachments) and auxiliary hydraulic setup front and back. This assuming a 40hp and larger tractor though.
/ Skidder or Tractor? If you could only have one. #9
Two different purposes. A skidder is specialized logging equipment and is the best choice for skidding logs, but it has few other uses. A tractor is multi purpose equipment and can be used to skid logs, but a skidder is much better for that purpose.
/ Skidder or Tractor? If you could only have one. #12
G'mornin.
Skidder or Tractor? If you could only have one.​
Your opinions??
Neither.
This is better:Compact telehandler
/ Skidder or Tractor? If you could only have one. #13
Right, which are we talking about? A Skidder or a Skidsteer? They are two vary different machines.
I think he was trying to be cute with the terminology. :cool:
/ Skidder or Tractor? If you could only have one. #15
I have a Cat track machine and a L3700SU Kubota.
The skidsteer is 10x the machine over the tractor.
It’s faster, stronger, and just far more capable with the front bucket. However.. it’s brutal on the lawn.
There are chores I do with the skid that the tractor just would struggle to do. And chores I do with the tractor that the skid would just make more of a mess than I would want to deal with. .But if I had to pick just 1.. it would be the skidsteer. .. it can do it all if need be.
/ Skidder or Tractor? If you could only have one. #16
Alright, with a small tractor and a more capable skid steer that makes sense.
In my case, the M6040 can lift much more than the NH L218 can. It's not 10 times the machine, but maybe about twice.
/ Skidder or Tractor? If you could only have one. #18
Anyone got a photo of a skid steer being used for row crop cultivation? Maybe AI?
:D
Bruce
And those front mounted rotary cutters on skid steers are scary for operators.
/ Skidder or Tractor? If you could only have one. #19
Why?
Mine is 7' wide and has never scared me on the compact telehandler:
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
New Holland 3930 (A62177)
New Holland 3930...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
