Longer bar for Stihl M261 - relative novice.
   / Longer bar for Stihl M261 - relative novice. #91
Exactly what I'd run, as well. Anyone who thinks they should be run with bigger bars isn't cutting a lot of large-diameter oak.
I'm presently running:
36cc = 12" (T435)
63cc = 19" (036 Pro / predecessor to MS362)
85cc = 28" (064 AV / predecessor to MS660)
I would never cut down a large diameter oak, at least not on my own property, unless it was a liability. Also, I know the 261 with a 20" bar would have no problem with it either unless I was cutting up 10 large oak trees in one day. One large oak = no problem.
   / Longer bar for Stihl M261 - relative novice. #92
"Large" is a relative term. To me, that means anything over 40" diameter at breast height, and you're never tackling that with a 20" bar on any saw, or any bar mounted on an MS261.
White oaks in particular, can grow very large here. The largest I brought home was over 6 feet in diameter at knee height, and still over 4 feet diameter 15 feet up, where hurricane Sandy had snapped it off.
That's a 36 inch bar on the Stihl 064 in the photo above, running full-chisel skip chain, apparently the day I bought and first installed that bar (ca.2012/13).
But even the red oaks are usually over 30" diameter by the time they either die or get damaged enough to take them down. MS362's, which are 26% larger displacement than MS261's, still struggle to pull a 20" bar through these without slowing down quite a bit. Anything can be done with infinite patience, but it's going to be slow, and it's going to be frustrating feathering the thing so tenderly that it won't constantly stop in the cut.
We get a lot of oak here, it's probably our most prevalent fire wood, excepting a brief window when all the ash started dying.
   / Longer bar for Stihl M261 - relative novice. #93
Sounds like we got a “who’s hung bigger” debate brewin. 😁 😁
I found another nice used 661C. Looks good. $650! Now we’re talkin….
Only one problem, the 3 hour drive each way kinda takes away from the great price. 🫣
I’m trying to see if he will dump the tanks, separate the bar off the saw and UPS it to me.
I sold a guy a saw that way. Went fine.
   / Longer bar for Stihl M261 - relative novice. #94
I've had a 261 with a 18" bar for years.
It's an OK saw but I wouldn't call it great by any means.
I don't have any larger trees to cut down so I'll stay with the 18" bar.
I don't think the 261 would do all that well with a larger bar.
   / Longer bar for Stihl M261 - relative novice. #95
Why is the only measure of a saws worth how well it performs buried dawgs-deep in hardwood?
I bet most people use saws for mostly other uses.
   / Longer bar for Stihl M261 - relative novice. #96
I run a 20” bar on my 261C because I like the extra reach when limbing a downed tree. I have a 25” bar on my 500i for the bigger stuff. Still have my old Dolmar 7900 with a 32” bar that I leave on all the time for the rare 25-30” oaks I get into
   / Longer bar for Stihl M261 - relative novice. #97
It's not! But the OP's question was about needing a longer bar on his 261, and he lives in the mid-Atlantic region, so we've already assumed he's buried to the dogs in hardwood.
Agreed. That's why we keep smaller saws. :p
   / Longer bar for Stihl M261 - relative novice. #98
Until someone from redwood country shows up, and starts laughing at all of us.
That might not stay available for long, if it's in good shape. Seller sounds trustworthy?
Some like to ask for a photo of piston with muffler removed, but that can be a lot to ask of a seller with a hot deal.
   / Longer bar for Stihl M261 - relative novice. #99
Redwood is big, but soft. Pretty easy cuttin.
Turns out, he is not in the part of MD I thought he was.
He’s “only” 2&1/2 hours away, not 3.
Still a lot of fuel & tire wear….
Tough decision.
   / Longer bar for Stihl M261 - relative novice. #100
View attachment 3572340 View attachment 3572350
View attachment 3572394View attachment 3572399View attachment 3572402View attachment 3572491View attachment 3572576View attachment 3572489
I like that 064…..nice saw
Would like it even better with a lightweight bar
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2013 Trailer (A60460)
International 565 Loader Tractor (A59814)
International 565...
(APPROX. 20) 4' X...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
