WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,529
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Good plan. And you can always run skip chain on longer bar and full comp on shorter bar. That's what I do with my 85cc saw, 28" with full comp and 36" with skip.I’m going to go with the guys who said get the longer bar but keep your shorter bar & chain.
I had a Super EZ Auto. Totally different animal than a modern MS-261. The EZ Auto's and their variants ran super-low RPM's and chain speeds, versus today's saws. They had comparatively higher torque, and had no problem pulling a longer chain, as a result of that.That being said, I now have 20” bars on all four of my Homelite super EZ Autos; the one I bought new in December 1974 was the last to switch from 16” to 20”. (I’m sure you can guess my favorite small saw.)
Those Super EZ Auto's were only 40 - 45cc, if I recall correctly, but had no problem running the same length bar that you'd put on a 55 - 60cc saw today.
I stopped buying Stihl bars when they got rid of the grease hole for the nose sprocket bearing. My two most recent were Tsumura Total and Windsor Speed tip, and I like both, but neither are very light.Whatever you do, don't buy a new Stihl bar (the ones with the funky design on them), they aren't all that good. Having said that, not my personal poinion, only what I've read about them.
The new Stihl lightweight bars are supposed to be pretty good, good enough that I might ignore the lack of a greasible nose and the silly foo-foo design that looks like it belongs in my mother's kitchen, ca.1995.
My dislike of non-greasible bearings has nothing to do with grease life or how a sealed bearing can perform over decades, but everything to do with hydraulic action, the ability of grease to eject wood chips and long-strand fibers generated when noodling large rounds. I've lost more than one bar in the past to long-strand wood fibers binding up around a sprocket nose.
Up to 40" diameter, in theory, but more practically 36" to 38" diameter. I cut a lot of trees over 40", so I use a 28" bar most of the time. I keep the 36" for those occasions when I need to cut something over 55" (literally once per decade), or more commonly, occasions when I need to fell a 30" tree without accessing it from both sides.Again, 20" is more than adequate for all but the largest trees anyway, least in my view it is.
lol... maybe for you guys cutting pines and firs in the west.What's all the fuss. The MS261's I have all came with 20 inch bars from the dealer. They work just fine.
