Equipment security cameras
/ Equipment security cameras #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Anyone have something like this?
I have been leaving equipment parked in the middle of nowhere, where there isn’t even a house nearby for years and have had 2 pretty bad vandalism attacks.
One was slashed tires, the other was someone jumped on the tractor hood and destroyed it. Would really like to catch the punks, then a knock on their doors with video evidence.
Looking for a camera that could be mounted in or outside the cab and would swivel to the approaching motion and send to my phone or maybe it would have to be stored in the camera itself?
What would be perfect is something that uses the tractors battery power.
I’m a novice at this stuff, so looking for suggestions or help.
/ Equipment security cameras #2
I don't want to be a downer, but I think what you want doesn't exist.
1) the camera itself will become the primary target of vandalism
2) using the tractor battery will cause it to be dead in days
3) isolated location, does it have cell coverage?
4) generally only game cameras have cell service and game cams don't offer "follow the movement" options
5) cell service for cameras isn't cheap
6) you may be disappointed in the cameras ability to identify people unless they are right in front of the camera and facing it
With all that, I think 4 game cams is your best bet... no movement tracking but facing every direction
/ Equipment security cameras #3
I wonder if you could lightly modify the mounting of something like this to fit the need? Cheaper than a slashed tractor tire if it doesn't work....
/ Equipment security cameras #5
The biggest problem I have found with game cameras (besides what was mentioned above about facial recognition) is that they don't always sense movement. I have one cam that I have set to take pics once a minute between 7pm and 7am. 99% of the pics that have an animal (including animals the size of deer) on them are on the timed pics and not motion detected. Matter of fact, I've had it where consecutive timed pics shows the dear moving across the field of vision. Not one was from motion triggering it.
With that said, I'd think you'd have to set it close to the equipment where they will see it and just trash that as well. Only saving grace would be is if it was able to upload the image before they trashed it. That will depend on how good of a cell signal the camera has. I know around here, the middle of no where, cell service is spotty at best.
/ Equipment security cameras #6
Look into car security cameras. There are some youtube videos of the LA home fires that were captured on the cameras on Teslas as an example.
/ Equipment security cameras #7
LittleBittyBigJohn, that negates a number of my points, good job.
Now all he needs is a way to power it, a way to protect it, and good cell service.
I don't happen to like Reolink due to their terms of service, but if they have this then others must, too.
/ Equipment security cameras #9
I have this camera. The 'tracking' feature is not very good. It does work, but the object it's tracking must be fairly close. Like within about 30'. Otherwise, I really like it.
It is powered with a solar panel. It will last about 3 weeks on the battery without the solar panel.
It needs cellular service to communicate. I buy a sim card for about $100 and it will last me at least 6 months. And I use a lot of data. There are options you can choose for data. My sim card is through EIOT Club and it will link to whichever of the big 3 cell services is strongest at it's location. AT&T, Verizon or T-Mobile.
@Hay Dude you could mount one of these on a tree near your equipment and watch it anytime. It will alert you when it detects motion, within about 60-80'. And you can tell it to pan and/or tilt from your phone. It also records sound, and you can even talk through it to someone near the camera. You can also trigger an alarm on it. You can also record video or pictures and you can set it to take a time lapse video.
I have several of these that I put on job sites, mainly to monitor weather and progress of the job.
I have all those.
Power: tractor batteries or solar panel.
Protection: Mounted inside the cab-probably hung from ceiling.
Good cell serivice: I have that most everywhere.
I plan on putting the camera inside the locked cab. They might not ever see it. Ot they might realize the camera is videoing them and run away.
/ Equipment security cameras #13
I think you should install multiple cameras on at least one tractor, powered by the tractor battery and running all the time. While you are using the camera, keep it sending pictures to wherever you can send them. The reason? Sooner or later someone is going to pull out in front of you while hauling that tractor, and cameras from a different angle besides your dash cam might be just what you need. Plus, if they are always online, you don't have to spend time setting them up. Whoever is doing the damage is very likely to see you setting them up, and act accordingly. You don't want them to know the cameras are there, or they will break into wherever they are to destroy them. Most likely, you won't have to run them more than a few months, because if they are good cameras and take good pictures, and well hidden, you will catch your culprits. Once they are caught, and you prosecute, word will get out. Won't be much need in keeping the cameras active after that. (but I would if it is not cost prohibited)
Most likely a couple of cameras on one tractor should be able to pick up enough of a wide view to catch someone approaching. Might require a little thought on how you park the other tractors around it, to give the cameras the best chance.
The semi truck I drive has cameras rolling all the time, and the images are constantly being uploaded. If something happens (I had a chicken run out of a yard all the way to the road and nail my truck in the side of the sleeper). I was driving 30mph and saw the chicken coming. I called safety and they backtracked about 5 minutes to watch it on video. They couldn't believe it once they saw it.
As far as getting multiple angles without having more cameras, consider adding rear view mirrors in the path of the camera. My forward facing windshield camera can see both front fender mirrors and has viewed several instances where people were caught trying to get into the truck or fuel tanks.
David from jax
/ Equipment security cameras #14
Interesting that you posted this. I was just watching a video from a local logger asking if anyone could identify the $%$&#&!" that was stealing his fuel on the forwarder.
He put a camera inside the cab, pointing the front of the machine which would cover the fuel tank area too and caught the thieves face very clearly.
Fuel stealing along with batteries and other parts is sadly a way too common occurrence. Lots of people have been using those hunting cameras hiding outside the machine. This another option.
At the end of the day, it needs to be something practical, quick and easy to setup. So a single camera might be the way to go.
I would go for something small, hiding in a corner inside the cab or something, covering the front of the tractor. Something that they can't see easily from the outside, specially at night.
I don’t have time to set up and break down a game camera(s) every time I move a tractor to a new field.
Needs to be part of the tractor, inside the cab, motion activated and swiveling.
I have a few customers that have security cams on their barns and I can usually park near them, but many places I don’t.
/ Equipment security cameras #17
Could you use one of the ReoLink cameras mounted on a magnet? When you get out of the tractor, put it on top of the cab so that the solar panel gets sunlight.
But, that would make it vulnerable to a thief. And your cab roof would have to be metal.
Or, maybe there is a place to mount one inside the cab? And the solar panel is not attached to the camera, so you could mount the solar panel on a magnet and move it to where it will get sunlight. Or even put it outside the cab and just run the wire through a window.
That’s exactly what I want to do.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Athens Harrow Scrapers (A64119)
Athens Harrow...
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
