FEL bucket not level (Horizontally)
/ FEL bucket not level (Horizontally) #1
Starrynights
Member
ontario
Kioti ck2620
I've had this CK2620 for only 15 hours, I noticed yesterday that the bucket is not level, its higher ~ 1" on one side. I'm not doing any super severe work with it, don't recall any operation that would have pushed it this way... nonetheless, this is what it is now.
Could the arm hydraulics be operating out of sync (can this be adjusted)?
Could the arms be twisted (is this fixable)?
Other causes?
Note:
- bucket/arms go straight/level when pushed into a full dump
- bucket rests level on ground when setting up to scoop or when tractor is off
- the cylinders appear to be fine (extend/retract the same amount on both sides).
And alternately... should I even care? Its not interfering with any operations... I can still fill and dump as I need to.
/ FEL bucket not level (Horizontally) #2
Have you actually checked the level of the tractor vs the top (or bottom) edge of the bucket?
2 quick things come to mind;
tire pressure uneven
loader arms not sitting in saddles properly
/ FEL bucket not level (Horizontally) #3
Another thing to look at is the loader arm crossover tube. If it's twisted even slightly, the bucket will not be level. It's not always easy to see, so get a straight edge on it.
I have not taken a level to it yet. I notice visually the out of level when I raise the bucket, vs the brush guard.
Tire pressure is OK (front and back are all at correct/same levels).
One difficulty is that I have no level ground or concrete pad to park on, as a reference point. I will inspect the loader arms closer, and check level of the bucket in reference to them (engaged and not.
/ FEL bucket not level (Horizontally) #5
Relying on level ground to reference things as straight and/or level is problematic.
On uneven ground select wood blocks under the tires (mostly rear ones) will get you close as the front axle will tilt, but you still need a solid level reference for the tractor body (rear axle) and then any loader attachment.
Doing more than my share of renos & alterations I have come to expect all 'assumed reference' points to be out of square and not level.
Get yourself a laser level (and camera tripod) and it will become your reference point for many projects.
/ FEL bucket not level (Horizontally) #6
A lot of threads on this topic. Most likely cause is improper assembly. Try light down pressure on a flat surface and then loosening the mounting bolts to see if it settles.
/ FEL bucket not level (Horizontally) #7
Did you buy this tractor new or used?
I suggest starting off with the basics on a CONFIRMED level concrete floor. I suggest using a laser similar to Coyotes to confirm floor is in fact level before parking the tractor in position.
Measure from ground to rear axle center line.
Measure at rear of tractor from ground to fixed point on tractor above axle mount.
Next go to tractor frame at both front corners (not bucket).
Next rear point loader above where it attaches to tractor.
Next to front mount of loader on tractor.
Finally at loader front edge just off the floor.
Open for suggestions from others to nail down the cause.
/ FEL bucket not level (Horizontally) #10
I have the same problem with my NS6010 that I just got Thursday evening and noticed before using it just testing loader movement. I’m also trying to figure out what’s going on since I didn’t expect that on a new tractor. If I find something out I’ll reply here.
It's new. Unfortunately I don't have any concrete to park it on. I think i will contact the dealer.... it doesn't seem like something that I can adjust or fix on my own (especially since I'm working on gravel or dirt parking).
I am 99% sure mine is, if just a hair.
Interesting.. I took a look at the brush guard yesterday.. it's definately level with the frame, but looks a bit off vs the hood (looking from the front to back, independent of the bucket)
/ FEL bucket not level (Horizontally) #13
I’m not sure if it was this forum or another where someone chased a bucket that wasn’t quite level. The dealer tried a few things to fix it and I’m not sure it ever did get fixed. I would figure out a way to check it before getting a dealer involved.
/ FEL bucket not level (Horizontally) #14
Checking bucket tilt on non-level, but
non-bumpy ground:
Put a level across the bucket- note the slope
Mark the rear wheels' contact patch locations
Move the tractor, put identical bricks/or other spacers on both contact patches, span them with your level, and note the slope.
/ FEL bucket not level (Horizontally) #15
Zombieda,
I have a bent right loader arm on my ck35.
If you raise the loader arms to full extension does one arm reach the end of travel before the other?
/ FEL bucket not level (Horizontally) #16
I drive mine to a local gas station near me and parked on their concrete pad.
For me, I noticed a difference in measurement from the bottom of the loader mount to the frame with the side that was higher having more space between the bottom of the mount and the ground. I made sure both rear tires had the same PSI.
If you can I’d check those on yours but I’m also still at a loss with mine.
/ FEL bucket not level (Horizontally) #17
Sounds like your loader mount isn't installed level? I imagine there must be a bit of adjustment available. Maybe loosen the high side mount bolts and see if that side slips down a fraction, levelling the loader?
/ FEL bucket not level (Horizontally) #18
Before I got too carried away with.... put a level (2 foot, 4 foot doesnt much matter here) across operators platform and note bubble position, lay level across brush guard (same bubble?), then loader towers, then place on loader bucket and note bubble position. Should take all of five minutes to see what (if anything) is wonky.
I put a 4' level on it.. noting the bubble positions. With the bucket lowered (on ground).. they are very close. When the bucket is raised, it goes out of level noticeably at the top pivot point nearest to operators platform. This is where it pivots on the frame bracket. One side moves higher, the bubble level is noticeably changed, and would explain the difference I am seeing.The bolts appear to be snug, I torqued them a while back with no movement noted... but maybe my torque wrench isn't up to snuff.
I'm going to try to observe any movement visually on that frame bracket when the bucket is raised.
/ FEL bucket not level (Horizontally) #20
Two hydraulic cylinders when they are the same size and plumbed together with a tee exert the same force when the load is applied evenly. Even if loaded uneven the cross bar of the loader frame should keep them even.
It is time to find a flat hard surface and pull out hr measureing tape.
1. Is each rear axle the same height from the ground?
2. Is each loader mount the same from the ground?
3. Are both pivot pins where the loader boom meets the mount thye same distance from the ground?
4. Are the bucket mounting pins equal distance from the ground?
If these measurements are equal the the problem is in the bucket itself.
Mst manufacturers to day turn out decent products But there used to be some terrible quality control making "straight" loaders.
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
