Spindle replacements for John Deere X380
/ Spindle replacements for John Deere X380 #1
jlanglois
Member
Ford 3930
I think the noise being created by the 54 inch mower deck on my John Deere X380 is coming from the spindles.
I could also be the blades.
I called the dealer about spindle replacements and they were over $100 each.
I know that they have the sealed bearings in them, so adding grease was a waste of time, but I wondered if replacing bearings would suffice.
The third market spindle replacements are in the $30 to $50 dollar range. Is there a manufacturer that I should look for?
Thanks
/ Spindle replacements for John Deere X380 #2
If you have access to a press, then it is not a bad job to remove the old and put in new.
With the deck belt off, you may be able to detect which of the spindles has the bad bearing by a grinding sound, if there is one.
Also may be able to feel the spindle after a mowing session and tell by the warmth (heat) which spindle is in need of a bearing or two.
/ Spindle replacements for John Deere X380 #3
If these are aluminum spindles, sometimes it can be difficult to remove the mounting bolts without breaking the spindles due to galvanic corrision of the threads.
/ Spindle replacements for John Deere X380 #4
The old parts site lists an alternate spindle for it: PN# A-B1JD71 You might see if your local dealer can get you a price. I couldn't find it on the shop.deere.com site as available.
/ Spindle replacements for John Deere X380 #5
Although the bearing can be replaced and this may be the most cost effective option, the key to this is getting the spindle off the deck without breaking the aluminum housing. Soaking the bolts with penetrating fluid before hand is a good plan.
Some that have posted comparison videos on youtube apparently have the opinion that the JD OEM spindle assembly is higher known quality than the aftermarket versions whose internal parts can vary. If the mower has many years of service left in it, going with the OEM spindle if needed might still be the better option if those comparison videos are accurate.
/ Spindle replacements for John Deere X380 #6
Thanks
Nothing wrong with OEM spindle price of ~$100 each!
At that price they were probably meant to be replaced once worn out...
/ Spindle replacements for John Deere X380 #7
It's easy to knock the spindle out and replace the bearings without removing the housing from the deck
In any case the X380 spindles are the 'new' style with studs and locknuts so they don't have the corrosion problem.
So - You can remove them easily if necessary.
Bearings can have the inner shields removed to allow greasing after replacement.
It's usually the lower bearing which fails due to grass, debris & moisture.
I leave the shields in the upper bearing and only remove the inner shield from the lower bearing.
Few operators can, in my experience, maintain a full housing of grease to ensure new grease reaches the upper bearing. Leaving the shield in that one ensures the OEM grease stays up there.
/ Spindle replacements for John Deere X380 #8
Why aren't we greasing these? These spindles rarely have bearing failures -in my world anyways. It sounds like an inspection is in order from here.
The grease zert is for show. The bearings are permanently sealed. I also found another source of noise.
The pulley on top of the spindle has a weakly defined octagon shaped hole to fit the shaft. Once it begins to slip it rounds out the hole. No amount of tightening will keep it from momentary slippage.
/ Spindle replacements for John Deere X380 #10
The grease zerk functions to allow a few pumps of grease to "seal" the area so water doesn't infiltrate. I give mine two pumps before each season.
/ Spindle replacements for John Deere X380 #11
Before retirement I was an engineer on this product. The Select Series premium spec'd decks have 20mm spindles with open bearings (NTN probably) with separate seals. Greasing the spindles DOES reach the bearings. The spindles are certainly rebuildable.
Don't confuse this with the 100 Series mass channel product (Greeneville TN) with 17mm spindles and sealed bearings. Greasing those spindles doesn't directly reach the bearings but fills the spindle cavity. This does help seal the cavity from condensation and pressure washers though.
/ Spindle replacements for John Deere X380 #12
So I have a 2023 X390. How often should I grease the spindles? And how many pumps (standard gun) each time?
/ Spindle replacements for John Deere X380 #13
Ha... I've been retired 9 years. I dont remember. What does the owners manual say?
I grease the spindles on my GX335 once every Spring (but I only mow about 25hrs/yr).
/ Spindle replacements for John Deere X380 #14
A couple pumps a couple times a mowing season, which is about 50 hours per summer. Does not need a lot.
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2013 PROCO KILL TRAILER (A60736)
2013 PROCO KILL...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2018 Dodge 5500 Bucket Truck 4WD (A61307)
2018 Dodge 5500...
1994 DAKOTA MANUFACTURING CO. / TRAIL-EZE LANDALL TRAILER (A60736)
1994 DAKOTA...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
