Bobcat 324 fuel issue?
   / Bobcat 324 fuel issue? #1
Joel/ak
Bobcat 324
2014 model. Has the kubota 722 engine in it. Never had a problem with it. A couple of weekends ago I was using it and it would start to bog at high RPM with no hydraulics being used. I would bring it down to idle and back to full and no issues. 5 minutes later start to bog again. Figured maybe my fuel gauge was off so I topped it off.
Wasn't empty. Then it started dying on me. It always start back up and run good then bog down and die. Starts again.
I parked it. I gotta get it back to my house but wife wrecked the truck so hopefully my dad can grab it for me.
New fuel filter last fall.
When I get it here, where should I start. Fuel or more electrical? Usually a fuel problem doesn't start so easy when it's "starved".
Thanks for any idea
   / Bobcat 324 fuel issue? #2
Could you have a restricted fuel flow? Enough for starting and low rpms but no enough for higher roms and a work load.
   / Bobcat 324 fuel issue? #3
Plugged air filter? Mouse nest in the intake?
Checked the air filter thinking the same thing but it was clear all the way down.
Also have an OEM fuel filter coming.
It's intermittent problem which is frustrating.
Wife used it the other day and ran great until she put it back in the barn and then it started bugging down again.
   / Bobcat 324 fuel issue? #5
It’s possible that the supply pump is weak and won’t deliver enough fuel at WOT.
It’ll be just fine at low idle and part throttle but at hi idle it would bog..
In a machine that works in “dirt” all its life, change the fuel filters 2x a year.. it’s GOOD insurance..& cheap.!!
   / Bobcat 324 fuel issue? #6
Years ago I had a tractor that had a similar sounding problem and it was the fuel transfer pump.
Been going through my maintenance manual and it basically only covers the injection pump and injectors.
I know the pressure it's supposed to put to the injectors but doesn't give a feed pressure to the pump. Gotta do more research on that.
10 year old machine, has 1500 hours on it and even though it's ran flawlessly, things get old and break.
   / Bobcat 324 fuel issue? #8
What about the vent for the fuel tank? I would check that as well. Sometimes there is a dedicated vent on the tank, other times, it vents through the cap.
Didn't think about the vent. Everything has to breath and sometimes the small things get overlooked.
That's why sites like this are helpful
   / Bobcat 324 fuel issue? #10
Fuel pressure TO the inj pump depends on which pump or pumps u have..
If it’s easier, just post a pic.
Giyi Pallet Forks (A57149)
Giyi Pallet Forks...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
Giyi Mini Backhoe (A57149)
Giyi Mini Backhoe...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
AGT Industrial YSRT14 Mini Skid Steer (A57149)
AGT Industrial...
