Whatever you feel like thread.
/ Whatever you feel like thread. #381
Back to an Ego zero steer mower review. Got the machine out and the OEM batteries were down to about 80% while the aftermarket 2 were 100% dead and not take a charge. The company who sold them on Amazonie were gone and I could not write a review of them, or send them back. They were close to one year old. Have now mowed twice this spring using the 4 OEM batteries and I am reminded just how nice this unit is to use. Did order 2 more batteries and blades for it.
What does a battery cost? Looks like OEM is the only viable option
/ Whatever you feel like thread. #383
If they save you 69 gallons of gas at $3.25 a gallon over their lifetime, you break even. Everything after that is gravy. (y)
Of course there's the electricity charge, but I imagine you'll break even if they last a few years. (y)
My neighbor across the street is on his 3rd year with his original batteries. Still smiling. ;)
/ Whatever you feel like thread. #384
Honestly, not that bad if you get a full season out of them. I burn $500 - $600 in gasoline mowing 3+ acres each year.
What's the OEM battery cost? It'll be interesting to see how their total lifetime cost compares to total lifetime cost of new aftermarket batteries each year. I predict OEM is cheaper, if they last more than 2 years.
/ Whatever you feel like thread. #385
How many batteries does it need to cut say, two acres at a time?
I burn about 48 gallons of gas per year as it stands.
I don't really know but our yard is small, like 100+ x 300+ft with buildings in it. If the grass gets tall, I can't mow it with 4 batteries. It can carry 6.
/ Whatever you feel like thread. #387
Do yourself a favor and start writing birthdates on your batteries with a paint marker or engraver, if they're not already marked as such. You're going to want to keep track, as the OEM batteries age over a presumed 3 - 5 year lifespan.
/ Whatever you feel like thread. #388
I cut about 2 acres of grass. In four years, I have put 60 hours on my 54" Bad Boy ZT. I do not keep track but estimate less than two gallons of gas per hour. 15 hours a year works out to about $100/year. Add in an oil change every two years for $20. $110/year.
Ego 10 Ah batteries cost $200. If they last four years, $800 every 4 years. And the Ego will not mulch leaves like the gasser will. If cutting 30 times a year, an electric might cost less but I only have about 15 cuts a year where I live.
The Bad Boy should last 30 years with my use. I am in my seventies and will never need to buy another ZT. The Ego looked a bit flimsy to me but should be good for most lawns. My lawn is reclaimed forest area and a bit rough in spots so a heavier duty machine made sense.
One size does not fit all.
/ Whatever you feel like thread. #389
15 hours per year, cutting 2 acres? How?
I run about 40 hours per year with my 72" Hustler. I also mow the yard at the barn which is about an acre, on top of that. After 6 years I'm at 250 hours. Just did my 6th oil change yesterday
/ Whatever you feel like thread. #391
Definitely. If you're only doing 15 hours per year, you just need the cheapest mower made, no matter what it costs per hour to run it. There is not enough usage to ever save on hourly operating cost.
But I'm surprised your hours are that low. I put about 100 hours per year on my ZTR mowing what's probably 3 acres of actual grass on a 4 acre lot. About 65 - 80 hours of that is actually mowing, the remainder being pushing a blower buggy around for blowing leaves.
We need to mow every 4 days here in April and May, often shorted to every 3rd day if rain is predicted on day 4, then weekly in early summer and fall. Those of us without weeds can go 2-3 weeks with no mowing in July into early August, when the grass usually stops growing, but we're generally mowing from April 1 thru at least Thanksgiving.
We've had a few bizarrely warm years (e.g. 2019), where we mow right up to Christmas. But as soon as I go thinking that's the new "normal", we get a year with hard frosts starting mid-October or snow by Halloween. Highly variable, but I've never had a year with less than 65 hours on the ZTR, or more than 110 hours.
/ Whatever you feel like thread. #392
Fuel, oil and filter run me about $165/yr. I've never done anything else to the machine in the past 250 hours. The bonus is that I can mow 3 acres in one go, and it only takes 2 hours.
Too bad the highest rated aftermarket batteries on Amazon were garbage.
And the Ego batteries are like $150 each for a 2.5ah. The 5ah is $250.
One battery is more than my annual fuel expenditure
/ Whatever you feel like thread. #393
There are definitely things I prefer to have a gas or diesel engine. Other things are better with a battery.
We have a small Greenworks mower my wife bought when we had a 2nd home in Longview (she was working remotely for a year). It does the job if you have a small lot. For me, the gas savings isn't the benefit. It's the lack of an engine and the maintenance and fickle nature. My Honda is a much better mower, but spends a lot more time being tuned, repaired or sworn at.
Fortunately, we longer have a real lawn. I could just use a weed wacker. The light mower is easier on my back at cuts weeds as well as grass. It's really only for bits I cannot maneuver the flail
/ Whatever you feel like thread. #394
I have been doing that with the 19.2V replacement batteries I have been buying for my old Craftsman tools. I guess it's interesting information to have, but it just makes me mad to see the replacements are only lasting for a year or so before biting the dust.
I guess I'm going to have to bite the bullet and invest in a whole new set of cordless stuff pretty soon....
/ Whatever you feel like thread. #395
To address some questions.
The hour meter says 58.8 hours. Maybe it is not working properly…
Unless we get a lot of rain, grass does not grow much. I have gone over two weeks in July and August between mowings.
I do not fertilize or water. I have no neighbors to impress.
I did not buy a $5000+ ZT to save money. I hate cutting grass. My old 48” rider took two hours and the ZT takes half the time. There was nothing wrong with the rider and sold it to my neighbor for $1000. Call it $4500 wasted to have a mower that will last my lifetime and saves me 15-20 hours a year of drudgery.
BTW, cut the grass last Thursday…first time this year. I will cut it again on Saturday.
Time for a new thread?
/ Whatever you feel like thread. #398
I'd try jumping the dead battery with a jumper wire from a good battery of some sort. It only needs small bump for it to register on your chargers, If it's like my cordless tool batteries that occasionally won't take a charge if it's completely dead due to the charger not registering any voltage whatsoever. Saved a few batteries, relatively easy and the googler might show you how to do it or use a multimeter to figure which prongs of battery to focus on.
/ Whatever you feel like thread. #399
I also date my batteries.
/ Whatever you feel like thread. #400
Bookmark 18650 Battery Store - Trusted Supplier of Lithium Ion Batteries and consider rebuilding dead battery packs. I believe that site sells better cells than you will find in aftermarket assemblies.
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2025 48in Land Leveler Skid Steer Attachment (A66734)
2025 48in Land...
2018 CATERPILLAR 320GC EXCAVATOR (A65056)
2018 CATERPILLAR...
