trenching attachment advice
/ trenching attachment advice #1
Bristol Fashion
bcs 737
Hiya, we're a csa here in Bristol, using a venerable bcs 737. Is anyone aware of an attachment that can dig a narrow trench suitable for burying 20mm black water pipe, ie narrow and around 30cm deep?
/ trenching attachment advice #2
/ trenching attachment advice #3
other option would be to use the rotary plow since you only need it under the surface.
/ trenching attachment advice #4
I've rented a self propelled walk behind trencher numerous times, it did a trench 6"x18" at over 100' feet per hour, in hard rocky ground. Take small 6" bites, (multiple passes). Well under $100/day.
/ trenching attachment advice #5
When I worked for Bell Telephone, we used a vibratory plow instead of a trencher. We used it to install black water pipe for later use as conduit for underground wiring.
Unlike a trencher, the plow made very little surface damage. On most jobs, you couldn't tell any work was done.
Many rental yards have them at reasonable rates. Unless you do a lot of work like this, it might be cheaper to rent rather than buy an attachment.
  • Good Post
Reactions: JJT
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2020 Mack Anthem...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
