Tractor dies when trying to go forward or reverse
/ Tractor dies when trying to go forward or reverse #1
le78628
LS XG3032HST
Hi, wondering if anyone on here may know the answer to this. I ha a LS 3032HST tractor that keeps dying. It would start up fine. Issue is when I depress a pedal to go forward or reverse that it would die. I've made sure that parking brake is off. Any thoughts on what else I can try or look at?
TIA,
James
/ Tractor dies when trying to go forward or reverse #2
Parking brake light on dash comes on and off depending?
Seat switch needs to made (butt in seat) when you press pedal. Might try to jumper switch to test.
/ Tractor dies when trying to go forward or reverse #3
Check seat switch and wiring. It will shut off if it thinks you are off the seat when pushing the pedals
Thank you, I'll try the jumper switch idea to test
I was able to go back out and look under the seat again but this time removing the protective sleeve on the wires. Sure enough, the wires had been pinched and severed.
Thanks again for sharing your thoughts.
/ Tractor dies when trying to go forward or reverse #7
And thank you for confirming problem, it helps all of us to learn
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
(32) 2"X5"X20' CHANNEL IRON (A60430)
(32) 2"X5"X20'...
John Deere 5075E (A53317)
John Deere 5075E...
2021 Honda Pioneer 700 4x4 Gas Utility Cart (A59228)
2021 Honda Pioneer...
