Tractor dies when trying to go forward or reverse
/ Tractor dies when trying to go forward or reverse #1
le78628
LS XG3032HST
Hi, wondering if anyone on here may know the answer to this. I ha a LS 3032HST tractor that keeps dying. It would start up fine. Issue is when I depress a pedal to go forward or reverse that it would die. I've made sure that parking brake is off. Any thoughts on what else I can try or look at?
TIA,
James
/ Tractor dies when trying to go forward or reverse #2
Parking brake light on dash comes on and off depending?
Seat switch needs to made (butt in seat) when you press pedal. Might try to jumper switch to test.
/ Tractor dies when trying to go forward or reverse #3
Check seat switch and wiring. It will shut off if it thinks you are off the seat when pushing the pedals
Thank you, I'll try the jumper switch idea to test
I was able to go back out and look under the seat again but this time removing the protective sleeve on the wires. Sure enough, the wires had been pinched and severed.
Thanks again for sharing your thoughts.
/ Tractor dies when trying to go forward or reverse #7
And thank you for confirming problem, it helps all of us to learn
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
2012 FREIGHTLINER CASCADIA (A60736)
2012 FREIGHTLINER...
