Anyone seen this attachment? What is it?
   / Anyone seen this attachment? What is it? #11
We used a similar unit that was towed by a tractor at higher speed. It was called a Rotary Hoe.
8' wide I think.
   / Anyone seen this attachment? What is it? #12
Roundup ready corn seed put most rolling cultivators in the bushes down in these parts, I sold a 4 row set that I had but kept my 2 row set for gardening, as someone else said once you have them adjusted properly let the hide go with the hair and don't look back till you get to the other end.
   / Anyone seen this attachment? What is it? #13
Hey all, hoping someone on here will have seen this before and know how/what it's used for. I found this around the barn. My FIL used to have a super A, 140 and years ago a JD 4010 I think it was.
I am hoping it is used to clear weeds out of the rows.
Also if someone has used this before do you mount it with the spurs pointing out? How deep does it run? Surface or all the way down?
It has a 1" shank so I could mount them on my cultivator mount.
Looks like a segment from a Lilliston rolling cultivator, used for cultivation and weed removal of row crops in California. There are righthand and lefthand units, can't see this good enough to tell which.
   / Anyone seen this attachment? What is it? #14
   / Anyone seen this attachment? What is it? #16
Anybody else hearing that Trisha Yearwood song?
"You was just another hayseed plowboy, who didn't have a rotor-hoe"
   / Anyone seen this attachment? What is it? #17
Not sure if you are joking around or not... 🥸
"...When you yourself was just a hay-seed plowboy, Who didn't have a row to hoe"
I've been there not a row to hoe and no rotor-hoe. :)
   / Anyone seen this attachment? What is it? #19
Must be I need to get my hearing and/or memory checked 😆
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A59575)
2019 FREIGHTLINER...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
Forklift (A56857)
Forklift (A56857)
Brandt Grain Vac - Mod. 5000EX (A59814)
Brandt Grain Vac -...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
