New grapple - W.R.Long Gladiator
   / New grapple - W.R.Long Gladiator
Is there a trick to manipulating the hydraulic connectors with a 3rd function diverter valve?
I find that taking the grapple off & putting it on is iffy with the ag connectors because of the pressure in the grapple lines.
Should I swap to flat faced connectors if this bugs me?
   / New grapple - W.R.Long Gladiator #22
Not sure which ones it is, but mine have a pointed like end. when they are hard to put in I pop the pointed end on the side of the tractor and let some juice loose... Works great for me.
   / New grapple - W.R.Long Gladiator #23
I have the same issue with flat faced connectors. Best way I found to avoid it is to turn off the tractor and cycle the hydraulics several times to bleed off any pressure. Still have to crack a hose on the grapple occasionaly to bleed off pressure.
   / New grapple - W.R.Long Gladiator #25
72 years old with 21 acres I've been trying to keep clean and 4-5 cords of firewood every year. I had reached the point where I couldn't cut, haul and burn brush due to my age. The Gladiator 56" grapple might be my solution. Looking to buy a Kubota L4760 HST (2017 with 700 hours) , taking the winch from my JD 790. We have a few stands of white pine and competition leaves a lot of smaller dead pines that were too big to burn. This should work well. Very good timing and I like hearing how many folks get good use from their grapples.
   / New grapple - W.R.Long Gladiator #26
When I install my grapple, I shut the tractor off and cycle the valve to relieve all system pressure. I always keep the grapple hoses connected to each other when it's off the tractor. I have never had a single issue with connecting the grapple this way.
   / New grapple - W.R.Long Gladiator #27
A couple of years ago I bought a EA 60" grapple to use on my Kubota L48. It works great for me. The only downside is that when down close to the ground I cannot see the very bottom corners. I have gotten used to it, but it would still be nice to see the corners. Just something you may want to consider.
Doug
   / New grapple - W.R.Long Gladiator #28
Hydraulic connectors all seem to suffer from this. I made a bracket for a clamp to help. I can often get one of them to connect or very close and then use the clamp to pull it closed. But I also turn the tractor off and then back on to the first position (electricals on, engine off) and then I cycle the diverter a few times to relieve pressure. When I am fighting a connection, I get the clamp on it, squeeze it a bit, go back and cycle the diverter, go back and add more clamp pressure, repeat until it clicks on. I later found out someone makes a similar tool from a bar clamp that you can buy. It would be better on a bar clamp as the jaws sometimes want to spin on the pipe.
   / New grapple - W.R.Long Gladiator #29
I'm a new, first time, grapple owner.
I used to cut, haul, and burn limbs and brush on my property too.
These past three weeks, I used the grapple (and a new dump trailer) to haul everything (except logs that I will process into firewood) to the dump (free yard debris dumping during most of May here). Hauled away 8 well compressed (grapple is great for compressing brush and branches) loads for a total of ~64 yards (~8 yards/load). No way could I have gotten rid of so much material in that period of time by burning.
For me, the grapple and dump trailer has been a game changer.
Oh yea, the grapple does a pretty good job picking up pine needles too.....especially if you rake them into piles first.
   / New grapple - W.R.Long Gladiator #30
For my new Massey GC subcompact, I have researched grapples for years and will make the purchase when I have time. Local to me there is a WR Long 48" grapple for $2400. I realize they had to put the cylinders on top due the narrow width, but the hose install looks gawdy and needs more protection. I won't rule it out but for $500 less and I get the Catawba.
Ford 8510 (A53317)
Ford 8510 (A53317)
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2017 Nissan Altima Sedan (A56859)
2017 Nissan Altima...
Toro Timecutter Max (A57453)
Toro Timecutter...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
