This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #11
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #12
Ramps, earthen dirt bank, several of your strong friends or one Anatoly.
I use to do engine swaps and I backed the pickup into the garage and had a come along attached to the header above… simple and worked.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #13
Have it dropped off in the nearest town that has a fork lift... load it on your trailer.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #14
The local delivery trucks from a freight terminal almost always have a lift gate.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #15
Usually you have to pay extra for lift gate service. You do that when you purchase the implement. You can have them back up to a space on your driveway where they can put the implement. Then you can unpack it if it's in a crate or frame and hitch it to the tractor.
If you pick it up at the freight terminal they will load it into the back of your truck or onto a flat bed trailer.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #16
I bought a 'used oil' furnace and a hoop house that were shipped from other states. They come to a Regional Delivery terminal via semi-truck and from there they arrived by box trucks equipped with lift gates. They were skidded on the the gates, lowered, and I took them away with loader forks. In your case, either drag it to the shop or uncrate it at the road and hook it up ! be sure to let us know how it worked out !
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #17
I've used my engine hoist to load/unload heavy items into the back of pickup trucks with no issues. Lift height would be my biggest concern, if the tiller is on a tall truck the engine hoist may not reach.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #18
Let this be a cautionary tale...there is a reason loaders are standard on most new tractors nowadays.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #19
Even the little backhoe on my BX23 had come in very handy for use as a sky hook… with weight in the loader if needed.
   / This is probably a stupid question, but...... how do you unload a heavy implement from the truck? I do not have a front end loader. #20
You need to get your plan, possibly from one of these suggestions. Then load it with unloading in mind.
Case skid steer wheels and tires (A56438)
Case skid steer...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
Deere 335P (A53317)
Deere 335P (A53317)
iDrive TDS-2010H...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
