Injector problem or something else?
/ Injector problem or something else? #1
AlbionWood
Albion, CA
Ford NH 1920
Ford NH 1920 with Shibaura N844 engine, has always started and run smoothly, but just recently began running a little rough, like one cylinder is occasionally missing. Hoped it was just bad fuel or moisture in the sediment bowl, so I cleaned the bowl and drained out the fuel tank, put Seafoam in the sediment bowl and new fuel in the tank. Starts fine and idles fine, but at 1500-2000 rpm it still misses just a little. I tried loosening the injector compression nuts one by one, bleeding each line, but that didn't seem to change anything. The engine isn't misfiring on every revolution, so that operation didn't indicate whether one injector was causing the problem. My question is whether this sounds like a faulty injector, or something else?
If it's an injector problem I will try to get a new set and replace them all at once - they don't look that expensive, the tractor has been cheap to run for many years, and I can't imagine life without it now. But I'd like to know if there is more I can do to diagnose the problem.
/ Injector problem or something else? #2
Fuel filter(s)?
/ Injector problem or something else? #3
I would check compression. but also make sure you can get the injectors out before buying them.
/ Injector problem or something else? #4
injectors rebuilt/replaced IS the least expensive option.
& a compression test while they’re out is an excellent idea..
  • Good Post
Reactions: D&D
OK, great suggestions. I have a friend nearby who probably has the compression testing gear. Getting the injectors out might be a chore as they are difficult to access; will probably need to detach the FEL.
If compression is low then it's piston rings?
/ Injector problem or something else? #7
The check valve in the fuel filter bowl is clogged open. When this happens and the fuel tank is not completely full, the pump will start to suck air as a back-flow. Use a vice grips to pinch off this rubber return hose. Then either clean the check valve or cut the air line and block it off.
We cleaned out just about everything out, put in an electric pump and still not enough fuel flow, other than at idle. Pinched off the hose and Bingo ! We have a winner.
Well I wish that was it, would be a relatively easy fix. But I went out and ran the tractor at 2000 rpm until it started missing, pinched the return hose shut, and nothing changed.
Did another round with Seafoam in the sediment bowl, this time after running the tractor fairly hard to get the engine warm. It runs fine on the Seafoam at wide-open throttle, but once that is passed through there is still a little missing/coughing. I think it is better than before though.
I don't see much evidence of a compression problem, it starts fine (almost immediately on turning the key) and idles fine, even at lowest idle speed. Running at full throttle I see no evidence of "blowback" in the PCV tube, and the exhaust isn't particularly smoky.
If the Seafoam treatment doesn't get it running good enough I will try pulling the injectors, bodge an adapter to push carb cleaner through them, and see if that works.
/ Injector problem or something else? #10
You could also put a electric pump on from a fuel jug to test the low pressure fuel system. There fairly cheap and easier than injectors to do.
I don't understand. Do you mean pumping into the fuel filter assembly instead of gravity flowing from the fuel tank?
/ Injector problem or something else? #12
Fuel jug to new electric pump directly to the supply to injection pump. If the problem still happens I would change injectors and check compression. If new Injectors and compression is good your prob looking at a high pressure pump if your pump timing isnt off.
I hope it's not the fuel pump, that's a pretty big job and getting the timing adjusted right looks pretty tricky. I'll work on the fuel supply end first, then the injectors, and if neither of those fixes it, I guess the fuel pump is the next suspect.
Having trouble finding new injectors that match the old ones in this engine. Lots of places offering injectors for Shibaura N844 but none of them have leak-off lines and they are apparently for engines made after 1999; mine was 1992. I finally found a part number, at Messick's, but they want $356 for one!! Searching by part number is turning up only a few hits and most of those don't have photos, so I can't tell if they really are the correct style. At least one place had the right part number but what is shown is the wrong injector.
Looks like I'm just going to have to pay up for these if it turns out that's what I need. Maybe for $1,400+ I will try cleaning the old ones.
/ Injector problem or something else? #16
How about sending them to me for testing and rebuild if needed.??
BEFORE you do damage..
What he says, you're working with minute tolerances, you can't take 'em apart, give 'em a rub with some sandpaper and hope the work. Send them to The Pump Guy you can't go wrong, haven't heard one negative thing about him.
/ Injector problem or something else? #17
It runs fine on Seafoam? Before you take anything apart please read my recent thread. Bad fuel!
I see you are 2 hours north of me. Your fuel may come from the same source.
Yeah I did see that thread when I first started working on this. Drained the fuel tank, changed fuel filter and O-ring, refilled with fresh diesel, added Seafoam. No observable effect.
Got the injectors out today and will send them out to be serviced. They look pretty bad, lots of carbon, I'm surprised it ran at all.
Well, shoot. Got the rebuilt injectors back and installed, put everything back together, bled the pressure lines and started the tractor up. As always it started right up, I ran it for a while and revved it up, and it started missing again. So there's something else wrong.
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
Misc Sprayer, Heaters, Saw Horses, Pressure Washer, ComeAlong (A62177)
Misc Sprayer...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
