Zero turn vs. 4X4 tractor for mowing
/ Zero turn vs. 4X4 tractor for mowing #61
We mow 30 acres and for several years used a Kubota tractor with a 7 ft finish mower. Now it did have a cab with ac, so was real comfortable. But it took way too long.
We switched to a Ferris 72 with a Kawasaki and never looked back. The adjustable air ride seat and suspension let's you fly over the ground. We have two friends that have them for farms also, and love them.
I have never had it "let go" and slide with me and trust it on inclines I wouldn't put the tractor on. Now it is a heavy machine and would bog down in low wet areas.
Of course, the larger deck you get the greater possibility of scalping uneven areas. We have a smaller 54" ZTR for trim work.
We kept the tractor and at first kept the bush hog and finish mower. But it was obvious, we were never going back. Still keep the tractor for bucket and other implements.
/ Zero turn vs. 4X4 tractor for mowing #62
IMHO you’ll need to mow it more regularly if you go to a zero turn. My recommendation for you would be the Cub Pro Z 700 or 900 series
/ Zero turn vs. 4X4 tractor for mowing #63
We mow 30 acres...
Damn! Even at 2 acres/hour, that's a lot of hours.
I mow every 4th day in spring, trailing off to weekly for most of the season after that, except a little break we usually get in the July heat and drought. Mowing every 4th day at 15 hours/mowing would be 4 hours per day on average, for 30 acres. :oops:
/ Zero turn vs. 4X4 tractor for mowing #64
I have the same model Ferris as the one you're looking at except mine is fuel injected instead of carbaurated and a year and a half old.. I like the fuel injection a lot. Really easy starting. I told my dealer I wanted an 800. He asked if I wanted a Briggs or Kawasaki. I said Kawaski. He called when they came in, gave me a price, I liked it and it showed up with the fuel-injected model.
As far as mowing, I don't think you'll find a more comfortable mower. I went with Ferris specifically because of the suspension. My back is in terrible shape and the surgeons say they can't do anything to help me. I mow 5 acres less the house, driveway and pool. It was a horse pasture, still not real smooth, and I used to mow about 4 1/2 acres with a CUT and 6' finish mower then trimmed the other 1/2 acre with a 48" JD lawn tractor. Took 5 to 6 hours depending on how tall the grass was. Checked the time last weekend after doing the whole yard without taking a break. Under 3 hours... and I fly on some parts, slowing down where I know there are ruts or holes.
The best part is when I get off the mower, I can walk and stand up straight pretty easily.
Let us know what you end up doing and if you have any questions about Ferris, just yell.
Same here. We moved to East Texas from SE PA. Our new property is 4 acres but with the buildings and garden closer to 3 acres.
First I bought a brand new eXmark ZTR... was $14k. After a year I could no longer handle the thing's hard ride and bouncing. Then I bought a 72" PTO finish mower for my Yanmar YT359C. Figured I'd do the major part with that and use the ZTR for the busy areas.
I didn't like how the rear 3PH finish mower was rigid behind the tractor. A pain when going around trees.
So I sold the finish mower and sold the eXmark. Bought a new Ferris 62" ZTR with that awesome suspension. What a difference and it was $9k. Only lost $1k on the eXmark so I came out ahead in a sense.
/ Zero turn vs. 4X4 tractor for mowing #65
For the past ~10 years I have been using my Ford 1620 HST 4x4 with 60" 914 deck to mow about 7 acres. I'm at the point now where I don't look forward to mowing due to many mower deck breakdowns (tractor is great) along with the the time required to mow all 7 acres. It basically kills one whole day of my weekend. I think the top speed of the 1620 in MED gear (fastest I can go due to blade speed and cutting) is something like 1.5 mph.
I have been hesitant to get a zero turn due to the fact I have a decent strech of mowing along ditches & pond banks (~1200ft of pond banks, ~ 1000ft of ditches), where sometimes it can be a bit wet. I have never gotten my 1620 stuck to the point I needed another piece of equipment to pull it out. The rest of the mowing is very flat.
I have been looking at thie Ferris mower: Ferris 5902073
I assume my cutting time will decrease, but it also seems like I am going to not be able to cut some areas, especially on the steep ditches?
I love my ISX800, it's a great mower.
/ Zero turn vs. 4X4 tractor for mowing #66
I am in the same situation. Mow about the same amount. So reluctantly I bought a zero turn. I hate the darn thing. Even when creeping along every time I turn it tears up the yard. If I could trade it and get a reasonable amount for it I would in a minute. My 4x4 tractor that is only used for mowing is slow but it doesn't make a mess of the yard.
/ Zero turn vs. 4X4 tractor for mowing #67
I've never taken the time to look closely at these, since the ZTR I have now was bought back in 2007 and probably still has another 10 years of life left in it. I assume the suspension must be only between the operator and the running gear, and not affecting the deck height?
I tend to turn and accelerate pretty hard, when the grass is dry enough to allow for it, and I can only imagine how the deck would be dipping and scalping if it were riding on any sort of suspension. Even as it is now, I can see the effects of my deck dipping in hard turns whenever my tire pressure gets a little too low.
/ Zero turn vs. 4X4 tractor for mowing #68
Zero turn for the back yard. I got it done before the rains hit that night. Most of what I use it for is areas like this. But everything else is mowed with the batwing.
/ Zero turn vs. 4X4 tractor for mowing #69
There is an art to turning without turfing but I turf some around trees but that's ok. I don't care if the grass around the tree gets turfed. The rear tires on a ZTR are wide on purpose... traction and stability. That inner tire making a tight radius will scrub the ground. I try and make sure that inner tire is turning as I go around to help reduce the turfing.
/ Zero turn vs. 4X4 tractor for mowing #71
To cut at commercial speeds with a zero turn(10+mph) you need a commercial grade suspension seat that can be tuned to rider weight or your spine will fall apart.
/ Zero turn vs. 4X4 tractor for mowing #72
"The system utilizes four upper and lower control rods that ensure the front caster bearing remains vertical through the full range of travel. This controlled motion results in a smoother ride, more precise tracing of the terrain and an improved cut."
/ Zero turn vs. 4X4 tractor for mowing #74
I recently went thru this decision-making process. 10.6 acres to mow in SE Oklahoma. We had a 50/50 hay arrangement with a neighbor but he sold the bulk of his cows and no longer needs the hay. I can't afford hay equipment just for 10 acres and I got tired of relying on someone to come cut it. Something always went wrong and it looked like a jungle out in front of our place where all the pasture is located. When the grass gets tall, the mice, rats and snakes all move in. So, we decided to just start mowing it ourselves (and by "ourselves", I mean just me :sneaky: ). We also considered just getting a couple of cows...but I know nothing about cows and would've had to fence 8 to 10 acres. So, the initial expense of the fencing and acquiring the cows kinda drove me away from that idea. Plus...I'm a softy with animals and I know a momma cow and her baby would just become my pets and I'd wind up caring for them for their entire lives. Anyway...
Looked at all the different mowing options and considered a zero turn. Then I found a great deal on a 2021 1025R TLB with a 60" auto-connect deck. Only had 88 hrs on it, looked brand new, and wasn't a lot more than a good zero turn. Plus I had all the capability that came with a small tractor with the loader/mower/backhoe. I was using a 3025E with a 5' rotary cutter but that just did a horrible job over uneven ground. The mower on the 1025R does a great job and I can cover ground a lot quicker. Of course, I have to keep up with the mowing so the grass doesn't get too tall for the mower to handle.
I wanted an offset flail mower, mostly for about 600' of ditch along the road. But even the 3025E couldn't handle one over 60" and that really didn't seem like much of an advantage over what I already had...especially for the price. So, I pulled the trigger on a 72" finish mower. Lowest cost option and, as a bonus, I can draft the wife into the mowing crew and we can cut two days of mowing down to one day since we can use both tractors.
/ Zero turn vs. 4X4 tractor for mowing #75
I was in the same position only I was using a compact with a loader (because it was a pain to remove) and a rear finish mower. So cutting around obstacles was a major issue.
I have a variety of sloped ground to the pond, ditches, bank along the driveway, around the pond etc. I cut around 5 acres sometimes more as the wife likes her walking paths done. Typically it was 9 hours for the major part and a few hours for the extra, so my weekends were cutting grass.
I started looking at better riding mowers, was considering the JD Signature I believe it was 735. Then I saw an ad for a Zero Turn touting it's stability on hills.
The salesman allowed me to demo it, I bought it and I'm happy. Might mowing time is down to 3.5 hours for most everything.
I'll say this, one of the large factors in stability is weight. I have a Hustler X-Onei 60". Traction can be an issue on wet or morning dew, but you learn. You can also use ag tires on it for more traction. Air pressure in tires effect handling. There is a learning curve, but I am glad I went the Zero Turn route. I'm careful around the pond and along the drive.
As far as mowers, if you can afford a more commercial mower, go for it. Better hydros are a better mower. I looked at Ferris back then, but it was pricy, but a good suspension will make life easy and comfortable. Mine has FlexForks that absorb most of the roughness. A good set of Gator blades will make it a beast that I can run through the field and almost use it as a bush hog. As I said, the heavier the better. I think mine was around 1285 pounds. My son and the salesman are more agile with it, I'm conservative because I've had a riding mower flip with me, so I'm naturally scared on anything that isn't flat. Always use the ROPs up.
/ Zero turn vs. 4X4 tractor for mowing #76
About 30 years ago, I spent part of a summer mowing for our school corporation. It was a rural area and the schools were built on farm ground that had been donated meaning each of the 5 schools (3 elementary, 1 middle, 1 HS) sat on several acres. I mowed the high school and middle school because they were on adjoining properties that totaled 80 acres while another guy hauled a mower to each of the 3 elementary schools to mow during the week. It took me 4 days to mow assuming I didn't get rained out. The largest open field was a little over 14 acres and it took me a full day to mow it. I spent the 5th day doing maintenance to the equipment. We used Kubota front runners (21hp F2100 FWD back then) with 7' decks. Most of the time I could mow at full speed (9-10 mph if I remember correctly).
At home I now use a (28hp) F2880 FWD. My understanding is that these machines are basically a BX series tractor built backwards. For wide open ground they work great. They also handle really tall and/or wet grass exceptionally well. If you have to mow around a bunch of stuff, then a zero turn would be better. For my personal use, a ZTR would be a better fit but I found the F2800 at a REALLY good price. It has a top speed of 12.5 mph, but if the grass is very thick or very heavy, it prefers to mow closer to 9mph. I've mowed through stuff that was over 6' tall, but it took several passes. For stuff that's a foot or 2 tall, it will mow it in a single pass, but it looks better if you make a second pass. If I had a rear discharge deck, I think it would handle really tall stuff a lot better.
The school now uses a tractor with a large batwing to mow the wide open areas. It mows the large areas a lot faster. A batwing is the only way a tractor can keep up with or outpace a ZTR for mowing.
/ Zero turn vs. 4X4 tractor for mowing #77
I assume my cutting time will decrease, but it also seems like I am going to not be able to cut some areas, especially on the steep ditch.
/ Zero turn vs. 4X4 tractor for mowing #78
Stick with the tractor you have and are comfortable with. Don't worry about cutting every last sprout along ponds or creek banks. Stay safe.
/ Zero turn vs. 4X4 tractor for mowing #79
Paul, I love your Husq R322T! I have a R155, 15hp 42" cut, that I've used for well over 2500 hours/23 years, cutting everything from 2 acres and more. Knowing that Husq no longer sells that mower in the US makes me sad. Let me know if you decide to "get rid" of yours :) Here's a pic of mine:
Admittingly, I do take better care of it than I do of my Kubota ZT.
My brother has a 155 and loves it as well,
Guess I will be keeping my r322t for now, like the easy on and traction as well as compact size
/ Zero turn vs. 4X4 tractor for mowing #80
You don't mention type of grass you are cutting - lawn, fields, pastures, etc... You are asking the right question and I can definitely give you some good advice! We have a 30-acre horse property in eastern TN - all grass in 7 different pastures plus grazing track and large lawn. I have an ABI 6' finishing mower for my Kubota tractor and a Skag 61" Turf Tiger2 zero-turn mower. For the first couple of years I used the finishing mower for the pastures and the Skag for the lawn - non-pasture areas. It became apparent to me that I can mow much more quickly with the Skag - even being 1' less cut width - plus the Skag can cut as high as 6-1/4" which is great for the horse pastures! I can mow 1-acre in less than 1hr. It takes me about 3-1/2hrs to mow my 5.5acre pasture as long as I don't have to backcut it because it got too tall. We have nice, thick pasture and lawn grass and if you have same - make sure you go with a nice powerful zero-turn like the Skag Turf Tiger2. That thing is a beast and powers through rough pasture grasses in late summer like butter! I hope this helps
FRONTIER LP2172 6' LAND PLANE (A64280)
FRONTIER LP2172 6'...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
(25) 2" X 2" X 63" TUBING (A64280)
(25) 2" X 2" X 63"...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-250...
