• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Reccomended Hydraulic Fluid
/ Reccomended Hydraulic Fluid #1
Amfab
Member
TX25
I see Summit recommends a VG 32 or VG 56 hydraulic oil in the owner's manual. I will be using VG 56 because of the warm climate.
Does Summit recommend a particular brand or brands, or certain additives?
Thank you
-Andrew
/ Reccomended Hydraulic Fluid #2
I don’t recall if I found an answer to this question when my TX25 was ready for its first service, but I went with Mobil Delvac Tractor Hydraulic Fluid.
After looking at a lot of specs on hydraulic fluids, the Delvac looks like a good choice/match based on the limited info in the manual. I was watching this the other day, which gives a lot of info.
I still would like to know if Summit has a preferred fluid.
/ Reccomended Hydraulic Fluid #4
They don't have a preferred brand. From the chart on page 50-9 of the Operators Manual it appears the oil grade VG 32 is best suited for when the tractor would be used in below freezing weather, such as snow pushing and under 80 degrees. The VG 56 would be best suited for warmer climates where the tractor isn't used in below freezing temps. Personally I've used the Traveller brand from Tractor Supply because it was readily available near me. They sell it in a 5 gallon pail and a 2 gallon jug. Get one of each and you have enough for the 6.6 gallon hydraulic fluid change.
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2007 Caterpillar C5000 5,000lb LP Forklift (A61567)
2007 Caterpillar...
2005 International 5900i T/A Gardner Denver Kill Truck (A60352)
2005 International...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2011 Jeep Grand Cherokee AWD SUV (A61569)
2011 Jeep Grand...
2013 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2013 Peterbilt 567...
Ad bottom of page
