Eagle1
Epic Contributor
- Joined
- Jul 4, 2003
- Messages
- 26,504
- Location
- Viburnum, MO
- Tractor
- Kubota BX2200, LS XG3135H, Grasshopper and Yazoo Zturns
Starter is 40334005Just got inside. After tapping starter with hammer while my wife turned the key, it started right up. Ground cable is clean, took it off anyhow, filed it a bit, plus the frame, still did nothing. Reminds me of my 77 Ford Supercab, had to hit the starter on it too.
Needs new starter, solenoid?
Here is a listing with other compatible numbers both LS and NH so you can shop if you want
https://www.amazon.com/DB-Electrical-Compatible-Replacement-MT40006954/dp/B08KHNJJ7X
DB Electric is a reliable vendor, I have used them a bunch
You may be able to disassemble and clean the solenoid, and maybe lightly lubricate the plunger. Inspect the contacts as well.
