PTO Won't Stop Turning (A Bigger Problem)
   / PTO Won't Stop Turning (A Bigger Problem) #11
Make sure you hold the turnbuckle with a spanner while your trying to loosen the nut . If all else fails you may be able to disconnect one end of the rod and turn that end to shorten it . It will be a little off center in the turnbuckle but that wont hurt anything .
Thanks Iron Horse. I might have not of thought about just disonnecting one end of the linkage. I had to take half of my dash off to get to the top of the clutch linkage but there was enough adjustment left to cure the problem so now the PTO stops just as it should and everything works fine. Also thanks to eveyone who replied to this post.
   / PTO Won't Stop Turning (A Bigger Problem) #13
Good find and good fix. Glad you got er fixed.
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
KUBOTA LA525 TRACTOR (A59823)
KUBOTA LA525...
