disney
Gold Member
- Joined
- Aug 11, 2012
- Messages
- 380
- Location
- orlando fl
- Tractor
- scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
lHello all. I am trying to help my neighbor install braces inside her 5"x"5 Pvc fence posts. The issue (there always seems to be one when I offer to help...) is after I dug out all the trash the contractor shoved into each post, I found the bottom rails (ground level) are nowhere near centered (from left to right) where they meet inside of the post. its about a 30/70 (so about and inch and change and then 3"+ ) with no gap between them at all. The brace has to go down the center of the post. it would be a very major deal to try to slide all the rails along her property line over an inch, when only two posts need the inserts/braces. I only have access from the top of the post, basically 6feet above ground uld not find any type of saw extension, or even saw that would fit inside and be able to cut through a PVC rail that is about 6 inches of vertical height. the blades on wood pruning saws are too tall, as the rails are about two inches from front to back, so that leaves less than 1.5" on either side (front or back) for a saw blade to fit between the inside of the post and the rails. I will have to try to add a picture, or make a drawing, but I want to know if I can buy a saw extension or if I should just weld and two blades onto a 6ft piece of steel, and try that with an old sawzall. as always, thanks to all to try to help.
